scale disolver?.ADDED PICS.
Old Jun 26, 2011 | 03:16 PM
steelhead2's Avatar
steelhead2
they inject fluid in the exhaust to burn all the "harmful" particulates out of it.first pass up the hill in my truck with 2k in the bed yielded ect200-eot205.hit the bottom and they both cooled perfect,ect191 eot196.coming home it eot would fluctuate between 196-197,ect being 191.almost got home and the eot stuck on 199,no more fluctuation.ran the hill again and got ect 200 eot 209,at the bottom the ect went down to 191 but the eot didnt follow.gonna flush again and price a new radiator.benny,do a search on the latest urea inj diesels,pretty interesting stuff.
Old Jun 26, 2011 | 03:20 PM
cartmanea's Avatar
cartmanea
Those numbers seem absolutely fine, why are you pricing a radiator?
Old Jun 26, 2011 | 03:26 PM
BLADE35's Avatar
BLADE35
well it looks like its getting unplugged slowly
maybe you could dump straight cleaner in at the egr port at oil cooler let it soak abit maybe you already did
when you pulled the oil cooler out was it the stock one bunch of holes in the top or had it been replaced with a smoth top updated one
Im trying to load some pics on I will try and get a shot of the old one
Old Jun 26, 2011 | 03:34 PM
steelhead2's Avatar
steelhead2
Went from 5-6* spread to a 13-18* in a matter of miles.once the eot gets to 209 it doesn't come down,unless I stop or floor it and get circulation through it.when its at 209 ect is 191.
Old Jun 26, 2011 | 03:40 PM
steelhead2's Avatar
steelhead2
Dont know which one,came complete wit the top on.worked awesome on my first pass,better than it did when I first put it on.but I could see it plugging on on my gauge.ill drain and backflush the cooler again and then flush with distilled.
Old Jun 26, 2011 | 03:45 PM
BLADE35's Avatar
BLADE35
thats when I get my biggest spread too when ECTs come down EOTs are slower to follow but still come back to 3-6 degree spread
I didnt use distilled water only soft water
I can tell the soft water feels slick with the hard water deposts out
Old Jun 26, 2011 | 03:55 PM
wulfman's Avatar
wulfman
Steel i see temps just like yours and have new cooler and all was flushed prior to installing new cooler your temps are fine.
Old Jun 26, 2011 | 04:43 PM
steelhead2's Avatar
steelhead2
Just concerns me that eot would go from 196 to 204-210 and not come down.ill try to post a pic of what I'm getting out of the radiator.its strange,ya know how when you watch your gauges,and something changes,you just know somethings up.
Old Jun 26, 2011 | 05:00 PM
cartmanea's Avatar
cartmanea
Unless you run at a fixed speed on the highway for a while, the oil temp will tend to be slightly above the water temp. Each cooler has some efficiency loss, so EOT will read a little over ECT. The main thing, is to ensure when under load for a while they don't get too far apart. We hauled our JD tractor up the mountain last weekend on my dad's gooseneck trailer, tractor and trailer combo is about 14k. Pulling up the mountain for about 5 miles, I monitored temps with AE and EOT was consistently 20F above ECT. I don't like 20 degrees separation, but given the heat load, that's not bad.
Old Jun 26, 2011 | 09:11 PM
BLADE35's Avatar
BLADE35
I know what ya mean steel a oil cooler thats 3 weeks old should have better numbers than that
when I look into my old oil cooler theres like a powder coating on the coolant side dont now if its the same or what
I didnt see any flakes when I flushed stuff out
Old Jun 27, 2011 | 11:02 AM
steelhead2's Avatar
steelhead2
Ford Truck Enthusiasts Forums - steelhead2's Album: pics. - Pictureafter flushing the radiator for 6 hours this is what i still get out of it,before and after restore and vc9 flushes.also,this is after lots and lots of clear water flushing.
Old Jun 27, 2011 | 11:03 AM
steelhead2's Avatar
steelhead2
Ford Truck Enthusiasts Forums - steelhead2's Album: pics. - Picturethis is whats starting to plug my oil cooler.it never ends.flushed it most of the day yesterday (radiator only) and continued to get these scale flakes out of it.
Old Jun 27, 2011 | 12:40 PM
  #28
gearloose1's Avatar
gearloose1
Get a new rad, bud.
Someone put hard (high mineral) water in yours before.
Old Jun 27, 2011 | 01:16 PM
  #29
cartmanea's Avatar
cartmanea
I would do more acidic flushes before spending $400 on a new radiator.
Old Jun 27, 2011 | 01:49 PM
  #30
steelhead2's Avatar
steelhead2
I don't know if that'll help any more cartmanea.it never stop coming out of it,no matter how much I flush it.I flushed only the rad yesterday and it never came clean.ran vc9, had temp spread of constant 5*, then it went up.got home and flushed the block.the vc9 water came out clean,until I got to the radiator.flushed it for another 2 hours and the pic is what I got out of it everytime.and that's after 24 flushes!.least I know the block is clean.
