P0404 code ?
Old Jun 18, 2011 | 10:53 AM
add2255's Avatar
add2255
P0404 code ?
My truck just through this code auto Zone said it was a egr code I have heard ppl say these codes could mean turbo any help is greatly appreciated o and the truck is a 07 psd 95k on clock
Old Jun 18, 2011 | 11:18 AM
bismic's Avatar
bismic
If you have had a calibration update in late 2009 (TSB issued on Nov 20) or more recently, the PCM was updated to eliminate the turbo from throwing a P0404 code falsely. If not, folks are correct ... it could be the EGR or it could be the turbo.
This code is an EGR "FLOW" code.
Old Jun 18, 2011 | 12:45 PM
add2255's Avatar
add2255
I thought turbos were either good or bad period
Old Jun 18, 2011 | 12:50 PM
BLADE35's Avatar
BLADE35
p0404 egr A control circut range/performance
you can try and clean the egr valve and also clean IAT sensor in intake manafold there both probably gummed up
but you may need a new egr valve
Old Jun 18, 2011 | 01:16 PM
add2255's Avatar
add2255
Where is that sensor at I cleaned the valve and the truck runs perfact and would a new valve be covered under warranty being that it has 95k
Old Jun 18, 2011 | 01:20 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is a picture of where the IAT2 sensor is.
Got the picture from here:
Powerstroke 6.0L Technical Intro Manual
Old Jun 18, 2011 | 01:23 PM
BLADE35's Avatar
BLADE35
its the two wire sensor in the driver side front intake manafold IAT sensor
the passenger side has a tube that runs to a MAP sensor right above the hvac box
Old Jun 18, 2011 | 02:07 PM
add2255's Avatar
add2255
So will a valve be covered ?
Old Jun 18, 2011 | 02:19 PM
BLADE35's Avatar
BLADE35
should be covered under warrenty
did you erased the code
does the problem persist
Old Jun 18, 2011 | 02:33 PM
bismic's Avatar
bismic
The 6.0L has a variable geometry turbo - variable inlet guide vanes to the turbine. A number of moving parts. It is not a case of being either "good or bad".
Old Jun 18, 2011 | 03:07 PM
add2255's Avatar
add2255
How do you earase the code?
Old Jun 18, 2011 | 03:18 PM
BLADE35's Avatar
BLADE35
dont erase the codde if its going to the dealer
but light should turn off on its own after a few cycles with no problems
Old Jun 18, 2011 | 03:30 PM
add2255's Avatar
add2255
Ok thanks I have shut it off several times and it hasn't went off but o well I ges I will take it to a dealer
Old Jun 18, 2011 | 04:26 PM
BLADE35's Avatar
BLADE35
it takes several cycles of warm up followed by a cold soak coolant temps need to change alot
it needs to get so hot then cool so much before its considered a compleate cycle
not shure of what temps the pcm want to see
and or the problem remains and you need a new egr valve
you said you cleaned the valve and truck runs perfict if it still runs ok give it a few days before you go to dealer
or go back to auto zone and let them turn it off and if it comes back on then you know its time for a new egr valve
Old Jun 18, 2011 | 05:44 PM
add2255's Avatar
add2255
It finally turned off the truck runs great still never missed a lik
TurtleRacing
15
Nov 26, 2007 08:41 PM
suzuki_vinson
13
Sep 17, 2007 06:11 PM
Jake65
Sep 2, 2005 03:09 PM
BigFord1977
General Automotive Discussion
Jan 30, 2004 09:20 PM
