Codes
Old Sep 2, 2005 | 09:52 AM
Jake65's Avatar
Jake65
Codes
Anyone know what a 542 code needs to be fixed. I had a guy put a scanner on the truck (92 F-150) and is gave us a 542 code.
Old Sep 2, 2005 | 11:49 AM
andym's Avatar
andym
542 is Fuel Pump Circuit failure - are your fuel pumps working?
Old Sep 2, 2005 | 12:52 PM
Jake65's Avatar
Jake65
It looks to me that there is no power to the fuel pump. put I have checked all the fusers and relays and shutoff switch. thats why I had a guy scan it. If the fule pump is bad should you still get power back to the plug for the fuel pump?
Old Sep 2, 2005 | 01:56 PM
andym's Avatar
andym
Yes, you should. Have you checked the dash switch? That's what routes power to the individual fuel pumps.
Even if you have a single tank, there is a jumper block inside the dash that takes the place of the dash switch.
Old Sep 2, 2005 | 03:09 PM
Jake65's Avatar
Jake65
where abouts is this jumper that would have to be the only thing I have not checked.
jonathan642
Feb 29, 2012 02:02 PM
shawbran
Sep 6, 2011 06:41 AM
meier63
Dec 14, 2010 02:40 AM
CalvaryMusicMan
3.8 & 4.2L V6
May 11, 2007 09:04 PM
