460 with HEI dizzy
Old Jun 15, 2011 | 08:50 PM
greenwoodford's Avatar
greenwoodford
460 with HEI dizzy
I have an 88 F250 with a carbed 460 swap. The swap was done half-assed by a previous owner (used the efi dizzy with carb). I finally got it swapped out with an HEI dizzy and now I have a VERY weak spark. I have a power wire straight from the battery to the distributor, the plugs are good, and the wires are good. I have reset TDC on the #1 a couple of times now and I know I've got fuel through the carb to the engine. Anyone have any thoughts? Thanks all.
Old Jun 16, 2011 | 08:31 AM
jas88's Avatar
jas88
When you say "HEI" do you mean like from a GM? I think that is called a DUI on a Ford, which stands for "Davis Unified Ignition". Is that the distributor (I hate the term "dizzy") you are talking about?
Old Jun 16, 2011 | 08:40 AM
bluesmanmike5's Avatar
bluesmanmike5
I run the DUI distibutor on my 351. It works good, but there modules don't last long. You can replace it with any standard HEI module, most are the old style 4-prong set-up. $15-20 @ most auto part stores. Mine went bad in under 12,000 miles. Ran good 1 day, then just went south. Really weak spark.
Old Jun 16, 2011 | 08:59 AM
greenwoodford
Yes that is the distributor I am referring to. Everything on the inside should be fine because it is brand new out of the box. The only thing I noticed that might be a problem was the spade terminal for the power wire was really loose inside the distributor.
Old Jun 17, 2011 | 08:01 AM
bluesmanmike5
Just pull the coil cover off of it, and you will see the power wire. Just check it to make sure you are getting a good connection. Should be 3 small screws holding the cover on.
Old Jun 18, 2011 | 09:22 PM
greenwoodford
Well I still don't know what's going on. I checked all the connections inside the cover and they're all good. I took the distributor out and cleaned up the connection area on the intake manifold to make sure it was grounding well; I think I might need to clean up the engine ground too though. After I cleaned up the intake to distributor mating surface I tried grounding out a plug with it connected to the #1 wire and I got shocked so I'm pretty sure the distributor is at least semi-functioning.
Old Jun 19, 2011 | 09:23 PM
greenwoodford
Well my buddy and I finally got the damn thing running. TDC was just a little off and the battery was really dead. Here is a video of the beast running again.
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid144.photobucket.co m%2Falbums%2Fr187%2Farriebillmax%2FIMG_0149.mp4">
Old Jun 19, 2011 | 09:28 PM
greenwoodford
My buddy and I finally got it running again. It ended up being TDC was a little off and the battery is really dead. Here is a video of it running. It has open headers right now because I have to modify the exhaust I have to make it fit. Also, sorry about the double post the video in the first one didn't work right for some reason.
IMG_0149.mp4 video by arriebillmax - Photobucket
Last edited by greenwoodford; Jun 19, 2011 at 09:30 PM. Reason: adding reason for double post
Turbo Dog
Jan 28, 2016 07:57 AM
ATC Crazy
Jul 31, 2014 11:14 AM
greenwoodford
Jun 28, 2011 11:02 PM
awfulaggravated
Electrical Systems/Wiring
Jul 15, 2007 05:42 PM
