need help with hei dizzy
Old Jul 14, 2007 | 05:30 PM
awfulaggravated's Avatar
awfulaggravated
i just bought an hei distributor for an early 460 of ebay from white performance (65.00), i slipped it in and hooked in the clip with the yellow , red and black wires into the underside slot, now with the ford i had a wire for the positive side of the coil and the wire coming out of the old dizzy, to the other side of the coil, well i have no cranking now, do i have to hook in a ign. wire?
Old Jul 14, 2007 | 08:45 PM
Franklin2's Avatar
Franklin2
You have to have power for your new dist. If you look next to plug you plugged in, there should be another spot that says "bat". Right beside it will be a spot labeled "tach". You need to run a new wire from the fuse box to the dist and hook to the "bat" terminal. Pick a spot that is hot with the key in run and start. Make sure you use at least 12 guage wire for the HEI dist.
Old Jul 15, 2007 | 05:42 PM
awfulaggravated
thanks a ton, sometimes i fell stupid asking dumb questions but the only stupid question is the one i dont ask!
tjdad62
Dec 28, 2014 06:01 AM
Foryota
Nov 14, 2012 03:31 PM
Wriz
Jun 21, 2012 07:43 PM
greenwoodford
Jun 28, 2011 11:02 PM
greenwoodford
Jun 19, 2011 09:28 PM
