need a fuel part, help!
Old Jun 14, 2011 | 04:56 PM
cfrazier77's Avatar
cfrazier77
Hopefully someone can help me with this. I have a 78 F250 4x4 and have replaced all of my fuel system except for one part which I can't get, and that is the part that is leaking! It is the metal fuel neck that receives the fuel and connects to the rubber gas tank connection hoses.
Does anyone know where I can get one of these? Does anyone know of where one of these is? I would be willing to buy one off of someone body if it does not have a rust hole like mine. LMC, NPD, and Dennis Carpenter do not have it.
Thanks a bunch in advance!!!!!
Old Jun 14, 2011 | 05:03 PM
HIO Silver's Avatar
HIO Silver
It's called, interestingly enough, a fuel filler neck. Maybe ND will chime in so be patient.
Alternatively, Ford tended to use parts across the product lines so I wouldn't limit the search to a specific model. Second, you could cut off the rusted section and weld on a new section of tubing or just a patch.
I feel for ya guys in the rust belt.. dang, even fuel necks get rotted out.. that's freaking intense!!!
Old Jun 14, 2011 | 05:21 PM
cfrazier77's Avatar
cfrazier77
Unfortunately the rust on it is so bad I don't think anything much can be done to it. It looks real thin and I can't tell where the exact rust hole is. If it welded on it, I have a MIG, it looks like it would just blow right through it.
Also, the local salvage yards don't have anything older than 80s anymore, St Louis area. These are going straight to scrap, terrible.
Old Jun 14, 2011 | 05:36 PM
grinnergetter's Avatar
grinnergetter
Im pretty sure if your bed has a fuel door I can help. I'll look tomorrow and make sure. You might try Green Sales in Ohio.
Old Jun 14, 2011 | 05:39 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
cfraizer77 PM sent to you, I got one and I am in Mo. Stop on by the FTE Missouri chapter and intro yourself on the June BS/chat thread.
Parts discount to FTE Missouri chapter members......
Old Jun 14, 2011 | 06:14 PM
77&79F250's Avatar
77&79F250
Ok its is held into the pocket behind the fuel filler door by a large rubber o-ring and a clamp attached to a hook bracket on the top side of the pipe.
Once I undo the clamps, I am just going to try and pull it out of the o-ring and then I'll get it in the mail to you.
Old Jun 14, 2011 | 10:18 PM
cfrazier77's Avatar
cfrazier77
Thanks, you are the best!!!
Question, it just sprang another leak. The metal fuel line sprang a leak right above the rear axle. Can I cut out the bad section and patch it with rubber fuel hose or do I need to replace the whole thing?
Thanks again!
Old Jun 14, 2011 | 10:30 PM
mark a.'s Avatar
mark a.
Make sure it's the right one, there are more than a few. Make sure the vent tube is in the right place.
Old Jun 14, 2011 | 10:51 PM
77&79F250's Avatar
77&79F250
It should be soft line from the sending unit to the L/H frame rail anyway. If its close to the end I would cut it off and go with soft line.
Old Jun 15, 2011 | 08:53 AM
77&79F250's Avatar
77&79F250
Filler neck.....
All right here it is, all cleaned up and ready to ship. To install I would install the rubber fitting in the cup behind the flap.
Put some vaseline on the tube slide it past where it should stop then back into your tank tube, that way you do not have to drop the tank again.
All you perverts stop laughing, its Ford truck part related, but yea sounds like a plot for a ****, lol
The rubber fitting is pretty pliable for the most part except for a small portion that is rock hard from fuel being on it over the years.
Old Jun 15, 2011 | 09:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Much more info than you provided is required, because...
1978 F250 4WD: There are TWELVE different fuel filler tubes, I kid you not! Looking one a these up in the Ford truck parts catalog is a PITA. There are 10 pages of listings, over 50 different types for all 1973/79's.
Styleside or Flareside bed? Mid-Ship or Aft Axle Fuel Tank? With or without Evaporative Emission (unleaded or leaded fuel)? Regular, Super or Crew Cab?
Sold new in Canada or in the USA? What is the truck's wheelbase?
Canada or USA: The DSO code on the Warranty Plate will define what city/country the truck was ordered from...post what it is.
Old Jun 15, 2011 | 09:49 AM
77&79F250's Avatar
77&79F250
Thanks Bill, I have my fingers crossed I sent him the correct one.
Where can he get the rubber gasket?
Thanks again for the parts schooling!
Old Jun 15, 2011 | 10:37 AM
NumberDummy
I assume this is a Styleside, so...which one of the three different types is it?
Aft axle or mid-ship fuel tank? Plastic or steel fuel tank? Regular, Stupor or Crew Cab?
You have to wonder what FoMoCo was thinking inre to some 1973/79 parts. Having pages of fuel filler tubes is ridiculous, and if you thinks that's crazy, consider this factoid:
1973/79 F100/350: There are TWENTY TWO different brake pedals, NINTEEN different power brake boosters, and SEVEN different clutch pedals, I kid you not!
1968/72 F100/350: There is one brake pedal, one clutch pedal.
Old Jun 15, 2011 | 11:00 AM
cfrazier77's Avatar
cfrazier77
It is a long bed, regular cab, metal behind the axle fuel tank, style side. It does not have Evaporative Emission and it is a leaded one.
Old Jun 15, 2011 | 01:38 PM
77&79F250's Avatar
77&79F250
Pretty close to what is came off of, except my parts truck is a super cab. Let me know when you get it and if it will fit.
I can alway hit the JY, but I am pretty busy so probably not as fast a turn around.
crazed87bronco
Oct 28, 2014 12:51 PM
Vsanzbajo
Jul 1, 2014 03:08 PM
vanwashe
Feb 26, 2012 05:14 PM
Yobrock
13
Aug 23, 2010 04:25 PM
stil190
Aug 12, 2010 11:41 PM
