Tach just started working...rmp question.
Old Jun 9, 2011 | 05:54 PM
kenpobuck's Avatar
kenpobuck
Ok the tach in my truck just started working all on its own tonight. It has not worked since I did the body swap. I want to make sure it is reading right. So does 21-2200 rmps at 60mph sound right. I have 3.55 gears with these 37" tires and the final ratio for the trans should be 1:1 with this t18. At 55 it reads right around 18-1900 rmps.
Old Jun 9, 2011 | 06:24 PM
Otahyoni's Avatar
Otahyoni
I think im at about 1850 at 55mph...
I use this to double check sometimes: Calulators from www.4Lo.com
Edit: that calc says im at 1940 rpm at 60 mph..... I always thought i was just a hair under 2k at 60 mph....dunno
Old Jun 9, 2011 | 06:44 PM
kenpobuck's Avatar
kenpobuck
Thanks, man. What size tires are you running on yours?
edit: sorry just checked and you got the same tires as me duh!
Old Jun 9, 2011 | 11:45 PM
Country_boy_2007's Avatar
Country_boy_2007
yep that sounds about right, i run about 22-2300in 4th doing 60. im running 35's and 3.55's
Old Jun 10, 2011 | 06:22 AM
Otahyoni's Avatar
Otahyoni
I thought that was in my sig... Guess i'll have to put it back...
Old Jun 10, 2011 | 04:07 PM
kenpobuck's Avatar
kenpobuck
I checked your profile lol. I thought that was what you were running but had a blonde moment!
Old Jun 10, 2011 | 04:09 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
My old 87 F250 had 3.55 with 235' tires
Rpm were around 2100-2200 at 55 mph. I am pretty sure it close to that.
Old Jun 10, 2011 | 04:27 PM
kenpobuck's Avatar
kenpobuck
Before the body swap I had 33's on it and the 88 tach worked. It ran at 2600 rmps with the same 3:55 gear. It is gonna be hard to give up that gear ratio when I swap in the 4:10's later this year. But I need the lower gears for towing in these hills and the ones futher south.
Old Jun 10, 2011 | 09:25 PM
Aune163rd's Avatar
Aune163rd
there are mountains in KY? I have 4.10s and i am GUESSING I am running bout 2500 RPMs at 65-70...
Old Jun 12, 2011 | 09:13 PM
dyoungen's Avatar
dyoungen
Anybody have a set of 3:55 gears they want to swap for my 4:10? I have a 1987 N/A 6.9 and would love to go to a higher gear. I live in middle georgia if that makes a differance.
Dbergeson
Jan 5, 2015 07:07 AM
hndacr
Apr 12, 2010 12:24 PM
expedity girl
21
May 26, 2005 10:35 PM
carpe_diem
Mar 24, 2003 12:06 PM
Hamstersbane
Jul 15, 1999 12:52 PM
