HELP! Trailer Wiring Problem
Old Jun 2, 2011 | 07:16 AM
1986Beast's Avatar
1986Beast
Ok, so this may be a dumb question, but I am currently installing a 7pin plug for my 1986 F250 that is already equipped with a 4pin. I bought a plug that all I have to do is tap into the brake controller, power, and the reverse lights. I was wondering where is the best place to tap into power and reverse lights?
Thanks for your help
Old Jun 2, 2011 | 07:18 AM
1986Beast's Avatar
1986Beast
By power I mean the Aux power lead.
Old Jun 2, 2011 | 08:27 AM
fellro86's Avatar
fellro86
For the auxillary power, you will need to run a wire from the front to the back. It is your discretion s to whether you would run it from the terminal at the starter solenoid, or from the battery terminal itself. I would recommend a version of circuit protection, whether it be a fuse, fusible link, or breaker.
Old Jun 2, 2011 | 09:29 AM
1986Beast's Avatar
1986Beast
Alright that's what I was thinking. Any idea about how many amps I should put in the fuse link?
Old Jun 2, 2011 | 09:55 AM
fellro86's Avatar
fellro86
Depends on how much draw you expect, and how heavy of wire you run. Typically, 20-30 amp should be sufficient.
Old Jun 2, 2011 | 10:28 AM
1986Beast's Avatar
1986Beast
Any idea on where I should tap into te backup lamps or will just taping in at the tail end of the truck be sufficient?
Old Jun 2, 2011 | 05:57 PM
fellro86's Avatar
fellro86
No reason you can't just tag in at the back. They don't draw as much power or as long a time drawing it.
Old Jun 2, 2011 | 06:27 PM
1986Beast's Avatar
1986Beast
Alright sweet thank you very much for your help
12secondstang
All Things Towing
22
Dec 1, 2020 01:54 PM
mr. grieves
Mar 26, 2014 08:04 AM
72Blazerod
Apr 30, 2008 08:33 AM
PETE'S_6.0PSD
22
Nov 15, 2007 04:55 PM
fordtruckfan90
All Things Towing
Sep 8, 2005 06:59 PM
