Upfitter 10A Question
Old Mar 25, 2014 | 12:54 PM
mr. grieves's Avatar
mr. grieves
I added a second power port several years ago on my 2007 6.0 and tapped it to upfitter #4 which is obviously a 10A. A bit later I got a small rechargeable StreamLight flash light so I added a 12v plug under the dash and tapped it also onto upfitter #4 and plugged flash light into and works like a champ. I just installed a Kenwood DDX 470 deck and got a rear camera. I have it all tapped in to the reverse light and want to tap it to this upfitter switch as well. Is that too much on it? The power rarely has anything plugged into it. So likely hood of all being used at the same time is rare and the camera is only on when in reverse.
Old Mar 25, 2014 | 01:21 PM
69cj's Avatar
69cj
That would be your call. Standard electrical rule of thumb is all loads should not total over 60% of breaker rating. I would not go over 80% myself.
Old Mar 25, 2014 | 05:58 PM
MisterCMK's Avatar
MisterCMK
What rule of thumb is that? Are you referring to loading a circuit breaker for continuous loads?
I wouldn't have a problem adding a backup camera to that switch.
Sent from my Telegraph using IB AutoGroup
Old Mar 25, 2014 | 09:10 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Standard national electrical code(nec) for line voltage 110-600 volt is 80% based on the circuit/ wire size; 12.5 amps for a 15 amp circuit, 16 amps for a 20 amp circuit, 24 amps for a 30 amp circuit and so on.
Old Mar 25, 2014 | 10:06 PM
78fordman's Avatar
78fordman
Keep in mind the nec definition of continuous is 3 hrs or more. You can run it at a 100 percent for non continuous loads.
Sent from my leash using IB AutoGroup
Old Mar 26, 2014 | 08:04 AM
69cj's Avatar
69cj
His truck and decision, exp. has taught me not to push circuits 100%. Eventually when least expected or needed it will catch up to you.
tgowers
Feb 13, 2009 11:28 AM
ABFord
Oct 20, 2007 07:01 PM
gingerbreadmaniac
Jan 14, 2005 10:54 PM
gingerbreadmaniac
Mar 15, 2004 12:35 PM
chriskli7
Aug 2, 2003 10:03 PM
