Move ICP Sensor
Old Jul 17, 2014 | 11:13 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by azhdrider50
I was thinking a length of braided stainless brake hose
High pressure hydraulic hose would suffice. However, I have a buddy in Oregon that tried it and eventually the fittings failed.
Josh
Old Jul 17, 2014 | 05:22 PM
azhdrider50's Avatar
azhdrider50
move the icp from heat
I JUST, came from a industrial hose store. 3 towns over.in mesa az. The thread is a 12m x 1.5 threads the female is the hard one to find,& they wanted to put together several fittings to adapt it. 7 it just looked all cobbeled up. so i walked.. OTHER people have had the same idea, to get the sensor away from the turbo,& heat. but Im told not only is oil temp 200 but the hose will need 100% duty cycle at 4,000 psi.? no wonder ford cant keep a icp senson together.. any more info would be help full..
Old Jul 17, 2014 | 06:15 PM
MisterCMK's Avatar
MisterCMK
Josh
Which end did it fail at first?
Old Jul 17, 2014 | 06:23 PM
Bullitt390's Avatar
Bullitt390
At the HPOP. Unknown if it was due to the psi involved (4000 psi) or failure from vibration.
However, it was the adaptor to go from the HPOP to -4 JIC fitting that failed.
There were no issues with trapped air as some have theorized nor response time from the extra length of hose.
Plan B was to remote mount from the passenger oil rail bleed screw thru the valve cover. I am uncertain if he (his name is Wes) has tried that approach yet, although he did I am sure I would have heard about it.
Josh
Old Jul 17, 2014 | 08:13 PM
MisterCMK's Avatar
MisterCMK
Got any pics of his setup?
Sent from my Telegraph using IB AutoGroup
Old Jul 17, 2014 | 08:27 PM
Bullitt390's Avatar
Bullitt390
I'll shoot him a text...
Josh
Old Jul 20, 2014 | 11:52 AM
azhdrider50
So, Obviously, Brake or hydraulic hose cant. take the heat & pressure. JUST like fords sensor.. That was My Thought, to get the sensor away from the heat of the turbo. How about some kind of super heat insulation.? Out Of ALL, These P.O.S. out There, Has ANYONE HAD Success with them.?
Old Jul 20, 2014 | 11:54 AM
azhdrider50
SO, Since The "HIGH PRESSURE HOSE" FAILED.- It Did NOT SUFFICE..
Old Jul 20, 2014 | 12:02 PM
Bullitt390's Avatar
Bullitt390
It was the adaptor that failed and not the hose.
However it was just passed along to me that the reaction time was greatly compromised remote locating the Sensor.
2 strikes against remote locating the ICP sensor.
Josh
Old Jul 20, 2014 | 12:23 PM
azhdrider50
Thumbs down Fail.
FAILURE. Is failure. & could waste a motor.! My point is I cant afford to chance it.. - I dont have it like that, to gamble & would not guinnea pig, on my truck I need to count on.for my lively hood. I would not suggest. to ANYONE. Something I would Not Bet My Life On.. Thanx for input. just a thought..
randypcourville
Jan 23, 2017 08:20 AM
cmypowerstroke
Aug 21, 2016 09:32 AM
Eddie C
Feb 9, 2016 07:00 PM
bulldog88
17
Feb 14, 2015 06:41 AM
sand1
22
Oct 5, 2014 09:37 PM
