Move ICP Sensor
Old Jun 1, 2011 | 10:52 AM
KRDiesel's Avatar
KRDiesel
Move ICP Sensor
Has anyone moved the ICP sensor on a 03 to the valve cover? Can you just purchase the pipe and mount it ?
Old Jun 1, 2011 | 12:24 PM
texans's Avatar
texans
I have read of people doing it. You will need oil rails, passenger valve cover, and wire harness for sure. You can probably just solder in some wire to make the plug work. I'm not really sure what else you would have to do to make it work.
Old Jun 1, 2011 | 12:59 PM
Unrealo4's Avatar
Unrealo4
I think he just means to extend the current location out from behind the Turbo. Useing a hard line kinda like ebp sensor is mounted.
joetech's Avatar
joetech
You will need late style oil stand pipes as well. There are a lot of parts required unless you can find a used engine to score everything from. You would probably want to change the left oil rail to match as well.
Old Jun 1, 2011 | 03:25 PM
KRDiesel's Avatar
KRDiesel
ok. More than I thought. I was thinking it was just a hard line that went from the current location to the valve cover.
Old Jun 1, 2011 | 03:32 PM
texans's Avatar
texans
no The ones in the valve cover are screwed strait into the HPO rail that's under the cover.
Old Jun 1, 2011 | 06:22 PM
Fordnatic68's Avatar
Fordnatic68
If you have access to a lathe and have some patience you could pop a plug out of one end and machine a fitting that will accept the icp and tap into the hpop rail. I wouldnt think it to be that hard. You would have to push the icp end through a grommet to seal oil under the valve cover. Not really rocket science. Post your idea or which way you decide to go. R
Old Jun 2, 2011 | 09:28 AM
KRDiesel's Avatar
KRDiesel
I am going to leave it stock. I have to pull the turbo anyway to remove the EGR cooler,
Old Jun 16, 2011 | 11:32 PM
kayak116's Avatar
kayak116
2004 F-250 Diesel No Start. Spray Starting Fluid in and it will start. May go for a month or a week without a problem. Live in San Diego.
Old Jun 17, 2011 | 09:42 AM
2006powerstroke90's Avatar
2006powerstroke90
Old Jun 17, 2011 | 10:20 AM
rdunagan's Avatar
rdunagan
im wondering the same thing tyler
Old Jun 17, 2011 | 10:29 AM
Rusty Axlerod's Avatar
Rusty Axlerod
You should start a new thread on the 6.0 page. (button is at the top). Some more info on your truck would be helpful also.
Old Jun 17, 2011 | 06:21 PM
cheezit's Avatar
cheezit
this seems kind of random
Old Jul 17, 2014 | 10:46 AM
azhdrider50's Avatar
azhdrider50
WHOA. Brain attack.. How About just a length of braided stainless hose to extend the icp away from the heat, & to where you can. get to it..
Old Jul 17, 2014 | 10:47 AM
azhdrider50
I was thinking a length of braided stainless brake hose
