ICP trouble's
Old Aug 20, 2016 | 01:23 PM
cmypowerstroke's Avatar
cmypowerstroke
ICP trouble's
I have an edge programmer and was wondering why I keep going through ICP sensors. Do they have an upgraded sensor for trucks with a programmer or something? Running with the ICP unhooked. Any information is appreciated
Old Aug 20, 2016 | 01:38 PM
Dirtscooter250's Avatar
Dirtscooter250
How does the pigtail look?
What symptoms are causing you to disconnect the sensor?
These are picky for Ford sensors, which are more expensive but work.
Old Aug 20, 2016 | 01:40 PM
cmypowerstroke
The pigtails look good. The truck start searching and actually died on me one time. I replaced the original ICP with a new one and it lasted about a month and then started the same sentence. So I put a new one in and it started acting up and I just unplugged it I was tired of messing with them.
Old Aug 20, 2016 | 01:42 PM
cmypowerstroke
Surging not searching
Old Aug 20, 2016 | 02:05 PM
cmypowerstroke
And of course the p1280 code
Old Aug 21, 2016 | 08:27 AM
Gas Guzlr's Avatar
Gas Guzlr
Did you put a FORD ICP in? If not change it to a FORD. Also, do you have scanner data to upload?
I recently went through something similar. The IPR can give basically the same problems as a bad ICP.
Old Aug 21, 2016 | 09:32 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The 7.3 is very particular about who is the manufacturer of the sensors. I would suggest this as your next replacement.
Injection Control Pressure ICP Sensor 97-03
cnm_mike
Dec 9, 2017 05:50 PM
RideDiesel88
Jan 28, 2015 07:30 PM
samsdad02
Nov 27, 2014 06:43 AM
szotty
Aug 9, 2011 08:43 PM
03superdoody
Sep 8, 2009 08:40 AM
