Noise is still there. Aaron, I might have you listen to it the next time I see you to make sure I am not imagining things. I also gotta spend a few minutes hunting down my oil leak. I just had to add 2 quarts and its only half way up the hatched area.
Been there, done that. Check your high pressure pump reservoir area for o ring leaks. Also check the large plugs at the front or rear of each head. There is a nice replacement plug with a teflon o ring instead of the rubber ring the engines were built with. And for heaven sake, stop using synthetic oil!!! Mine started leaking right after using Rotunda synthetic!!!
Another area to check is the oil to coolant heat exchanger on the lower driver's side of the engine. They are not painted and start rusting. The rust creaps under the o rings lifting them causing a leak.
Reason: more info
winner winner chicken dinner!!! once wife is gone to quantico we will begin the late night offy build.
i will be taking the mustang through emissions tomorrow, hopefully they dont look under the car. it will pass other than the visual. if it fails i have the stock h-pipe (cats) sitting at rays shop ready to go on. its just a huge pain in the **** and waste of time.
kyle ill give you a shout some day this week, maybe a few of us can have a pizza gtg and ill grab that bike.
