Sponsored by: Real Truck
'Thump' when moving forward
Old May 23, 2011 | 02:06 PM
PMDRACER's Avatar
PMDRACER
Hey all -
'99 SD, V-10 automatic. When I take off from a light I feel this 'thump' in the truck, almost like if an object in the bed was sliding back and hitting the tailgate, but not as severe. Is this the slip joint noise I've read about?
Thanks in advance.
Old May 23, 2011 | 02:48 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
That is what I would think. Here is the how to. Slip joint regreasing
Old May 23, 2011 | 03:19 PM
joverstr2's Avatar
joverstr2
I think my 08 is doing this. Is it ok to leave as is or does it need attention?
Old May 23, 2011 | 04:02 PM
miller_feed
Being you have a truck still in warranty, I would let the dealer take care of this. Seems young to be having dry slip joint.
Old May 23, 2011 | 04:12 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I agree with Rick. Sounds like your slip joint is sticking. Couple of things to add....
  1. Make SURE you chock the wheels before disconnecting the driveshaft. You don't want your truck rolling down the road/driveway...or worse, over you while you are under the truck
  2. I use Super White Grease from NAPA. Lasts longer than the Ford grease...
  3. Shift into neutral to make it easier to R&R the driveshaft
  4. Check the U-joint bolts a day or two later to make sure they aren't working themselves loose.
  5. Don't over-grease. Too much will have a hydro lock effect and can damage other parts of your drive-train. Test by inserting the collar all the way down onto the splined shaft to make sure it has full travel.
Old May 23, 2011 | 05:43 PM
PMDRACER's Avatar
PMDRACER
Thanks for all the responses guys. For whatever reason, I can't open the TSB list in the Tech Section here at work. Someone told me there was a TSB for this.
The fix is obviously as simple as falling out of bed. Never in a thousand years would have thought it was the culprit though.
Old May 23, 2011 | 11:28 PM
Fordfanatic4life's Avatar
Fordfanatic4life
its more of a annoyance issue then a safety or need to have repaired thing, when it comes to the slip joint "thump" issue..
wether you fix it or not, is really just a personal call.
Old May 23, 2011 | 11:40 PM
CuNmUdF250's Avatar
CuNmUdF250
Remember the first time I felt that thump immediately assumed the trans or something was about to always thinking the worst oh and you have seen my face when the speed sensor thing on top of the back axle went bad holychit man
Old May 23, 2011 | 11:54 PM
jh818's Avatar
jh818
Ya gotta watch out for those Prius and Smart Cars getting trapped underneath.
Old May 24, 2011 | 12:12 AM
PMDRACER's Avatar
PMDRACER
Originally Posted by CuNmUdF250
Remember the first time I felt that thump immediately assumed the trans or something was about to always thinking the worst ....
Exactly. For the past two weeks I've been thinking trans or torque converter and watching the $$$$ go across the windshield.
Personally, I find it quite annoying but now I'll be able to live with it until I have a free day off to deal with it.
christyj
20
Dec 15, 2014 11:33 AM
ibo
Feb 14, 2011 12:24 PM
kirkharrod
May 8, 2009 09:16 PM
kystangbanger
Apr 7, 2009 08:47 AM
tebby
Jun 17, 2008 11:21 AM
