Sponsored by: Real Truck
Please help !!!
Old May 19, 2011 | 07:49 PM
mdunny12's Avatar
mdunny12
Please help !!!
I have a 01 superduty that will not stop leaking trans fluid. I have replaced the pan, pan gasket and the seal between the transfer case addapter plate and the trans. any thoughts or help would be greatly appreciated. It looks like it is leaking from the pan gasket on the back of the pan. But with the new BD 11 quart pan on thier I am not sure. wondering if any body else has ran into or heard of a stang trans leak ???
Old May 19, 2011 | 08:33 PM
bubbasz1's Avatar
bubbasz1
Is it by chance overfilled, there is a vent on the top of the trans and if it get hot it will puck oil out the vent.
Old May 19, 2011 | 08:34 PM
bdivine32's Avatar
bdivine32
well they make a dye you can put in your oil or tranny oil and with a black light, you can see where the fluid is leaking from. I know NAPA auto sells the dye and not sure where u can find a inexpensive light. Maybe a cracked case.
Hate to see ya have to go to the Dealer.
Old May 19, 2011 | 08:41 PM
cablemanF250's Avatar
cablemanF250
I never had a trans leak, but my transfer case did and it would leak after a day of sitting, took 3 trips back to the dealer for them to fix it, it had a micro fractor in the front half. that would only leak after it ran then sat over night. the way i spotted it was to clean it as good as i could get it, then use a black light at night, and marked it with a marker.
Old May 19, 2011 | 11:33 PM
bdivine32's Avatar
bdivine32
Well, have you tried Bubbaz1 idea and the vent. I never knew about the vent, but if its over full, it will find somwhere to get rid of the extra... Do you check your fluid the way Ford says to do it? Have you always had this leak or did it just start? Assuming the pan is aluminum, did you tourque it correctly?
Old May 19, 2011 | 11:51 PM
GUNNERDOG's Avatar
GUNNERDOG
my cooler lines were leaking where they connect to the trans. It was dripping down the side which made it look like it was coming from the pan...
Check those connections.
Old May 23, 2011 | 08:39 PM
bdivine32's Avatar
bdivine32
Oh Man!? Really? Thats a pisser! Did you ever have the lines off? Tranny flush? Sorry Man. A lot of frustration over a loose line. Well that dye would have come in handy there. It glows a Bright Green Just Follow the trail to the source. Oh well. I'll take that 11 qt pan if your lookin to trade it out
Glad ya found it!
Old May 23, 2011 | 09:35 PM
GUNNERDOG's Avatar
GUNNERDOG
Not exactly sure why the lines were leaking, but I suspect rust. I got a pair of new ones from the dealer. Easy install.
ryanelwood
Jul 11, 2013 10:35 AM
moneypit79
Jul 8, 2013 08:27 PM
billy g
1978 - 1996 Big Bronco
May 12, 2009 01:29 AM
hster
Jul 17, 2004 10:46 PM
