EGR Valve Removal?
Old May 9, 2011 | 05:49 PM
AndeyHall's Avatar
AndeyHall
EGR Valve Removal?
Trying to take my egr valve off to clean it...got the 2 bolts off and that baby still ain't budging! What's the deal?
Old May 9, 2011 | 05:54 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Deal is, they are tough little suckers to get out.
You already undid the bolts.
Twist the valve so the bolt eyes are open.
Loop heavy wire through each bolt eye.
Make a loop with the wire above the valve.
Use a long ratchet handle or some thing strong.
Put through the wire loop.
Use alternator as a leverage point.
And "Pop that little sucker out of there".
Still didn't come out? "EAT YOUR WHEATIES ALICE"
Try it again, it will come out.
Old May 9, 2011 | 06:10 PM
hubler13f's Avatar
hubler13f
LOL!!!
Took me like an hour and a half to get it twisted out of there the first time I pulled mine. The more gunk that is built up on it the tougher she is to pull.
And don't think you can use channel locks on the top plastic part and try to finess the thing around, it just leads to breakage. It seemed like a good idea at the time though.
Old May 9, 2011 | 06:26 PM
wulfman's Avatar
wulfman
Look the wire trick works great but if you have a little mini flat bar, home Depot has them and pry as you lift with the wire it will pop right out.
Old May 9, 2011 | 06:38 PM
AndeyHall's Avatar
AndeyHall
Well the POS wouldn't come out. I put the bolts back in and am just gonna cut my losses today and wait till I can get a friend's help.
Another problem though! The bolt on the passenger side broke as I was putting it in! And I put barely any pressure on it. I think the problem was I didn't let the truck cool down enough and the bolt got too hot from the engine.
Another question though...if I have an EGR delete done...should I keep my valve plugged or unplugged? It's on an 03. The reason I ask is because I'm having boost issues and don't know if the valve could possibly be to blame
Old May 9, 2011 | 08:49 PM
mah77's Avatar
mah77
I put the claw end of my hammer just under the lip. Popped right after a pry or two, and mine wasnt cleaned the for the first time til 27,000 miles.
You can unplug yours, 03-04 dont throw a check engine light.
Old May 9, 2011 | 09:49 PM
hubler13f's Avatar
hubler13f
It may not throw codes but there is plenty of info on here that connects the EGR valve being plugged in to proper fan function. I have an EGR delete and left the valve plugged in for that purpose.
Old May 9, 2011 | 10:04 PM
AndeyHall's Avatar
AndeyHall
What about the people who have block-off plates?
amory
Oct 31, 2008 03:52 PM
clevelandjim
Feb 21, 2005 08:04 AM
Ford427Strokr
Mar 18, 2004 12:21 AM
JCastellaw
27
Jan 20, 2004 08:04 AM
mathelm
1983 - 2012 Ranger & B-Series
Jan 14, 2003 04:07 PM
