Problems while starting when warm/hot...
Old May 6, 2011 | 12:31 AM
ech0sh4y's Avatar
ech0sh4y
The bronco starts fun when it's cold. But after making a run to the store or where ever, once the water temp gets up to normal, it has issues starting. it will start but then will idle super low like it's starving for fuel and sometimes kill it's self. If i give it some gas it will idle up then back to normal. I'm just worried it won't start on me one time. Any ideas on this?!?
Old May 6, 2011 | 08:19 AM
timbersteel's Avatar
timbersteel
Just throwing this out there...Any CEL flashes?
Only other thing I can think of right now, is the PIP. Would be part of the ICM/TFI or perhaps the Dizzy if the stator is going out??. I think Lew, RLA2005, and Subford have a bit more knowledge on this. Sounds very close to what your describing.
Could try the hairdryer trick and heat the TFI/ICM module up and see if you have a hard time starting it when the engine is cold.
Old May 6, 2011 | 12:49 PM
ech0sh4y's Avatar
ech0sh4y
where is the TFI/ICM (what does that stand for)? located?
Old May 6, 2011 | 12:50 PM
ech0sh4y's Avatar
ech0sh4y
TFI - Thick Film Ignition? What the heck is that...
Old May 6, 2011 | 01:34 PM
subford's Avatar
subford
TFI is a type of ICM.
ICM=Ignition Control Module.
Your Bronco takes a Black one but they will try to sell you the wrong one and the wrong one will be a Gray one.
But I dough the ICM is your problem.
More likely a bad ECT or IAT sensor.
But you need to check to see what codes you may have stored.
Old May 6, 2011 | 06:13 PM
ech0sh4y's Avatar
ech0sh4y
I have a ford tester to the non obd2 trucks. I have not had a cel on and I disconnected the bat. I'll take to parts house and see if there is anything stored. It's frustrating. Thanks for the idea though!
Old May 6, 2011 | 06:20 PM
subford's Avatar
subford
If you disconnect the battery or remove it there will not be any stored codes to read.
Old May 6, 2011 | 10:10 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Interesting, my 89 F150 300-6 does this also. But it's intermittent, doesn't do it all the time. most of the time though. Starts fine cold, warm/hot starts fine, revs low/stalls or stumbles really low then comes back up by it's self after 5-10 seconds.
Old May 6, 2011 | 11:59 PM
timbersteel
I would check the ECT or IAT sensor as Subford described earlier. Using a DVOM, check the resistance of each sensor Cold. Then drive the truck until warm and then get another reading for each sensor. If either one haven't dropped significantly, then this is starting point.
Also want to note, the IAT=Intake Air Temp sensor can get all gummed up. I try to remove mine once a year and clean it, to ensure it's not coated in deposits. As far as the ECT sensor, I wouldn't repace with a cheap brand replacement. I believe Ford still makes this part with a rigid housing and a brass tip. The newer aftermarket ones are plastic. Have heard of 2 people breaking these off when they are seized or could also have been in a hurry.
Hope this helps.
Old May 9, 2011 | 09:52 AM
ech0sh4y's Avatar
ech0sh4y
Where / what is the ECT sensor? I can get the IAT cleaned up and I will perform the resistance test.
No codes stored either FWIW. But I do notice that every time I fill up at the gas station, when unscrew my gas cap, it sucks/blows alot of air... i this normal?
Old May 9, 2011 | 10:10 AM
subford's Avatar
subford
Engine Coolant Temperature Sensor (ECT)
For more information on the ECT go to this link:
Ford Fuel Injection » Engine Coolant Temperature Sensor (ECT)
AS for where, what are we working on?
What engine, year?
Old May 11, 2011 | 02:25 AM
ech0sh4y's Avatar
ech0sh4y
ECT has been changed. Both the gauges sending unit and the computer sending unit.
gappy
Nov 10, 2008 03:03 PM
alz
13
Dec 2, 2007 04:33 PM
Truckerteacher
Oct 29, 2005 10:47 PM
jeffwecker
Jul 22, 2005 04:37 PM
