Is This Idle Normal?
Old Nov 10, 2008 | 02:12 PM
gappy's Avatar
gappy
When I start my truck it idles at 700 rpm's. After a couple minutes it jumps up to 1,100 rmp's. If I tap the brakes it drops back down to 700.
Is this normal? If it is normal, why does it do that?
Old Nov 10, 2008 | 02:25 PM
megawatt00's Avatar
megawatt00
That is normal Tom. What is happening is the wastegate is closing and the engine is increasing the rpms to help it warm up quicker. When you step on th brake or the go pedal the rpm's return to normal. You'll probably notice a whooshing sound coming from the exhaust, this is normal too. I have a 4" turbo back exhaust and on a cold day it sounds like a jet getting ready for take off.
Old Nov 10, 2008 | 02:28 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
My truck will start to do this when the temps start getting down around 35-40. Sounds just like a jet engine!
Old Nov 10, 2008 | 02:53 PM
gappy's Avatar
gappy
I was hoping to get an answer like that! Thanks!
Excuse my ignorance, I'm new to the PSD world....does the wastegate "bleed" off excess boost to bypass the turbo, hence the exhaust note change?
Then once the engine is up to temp it should idle at 700?
Old Nov 10, 2008 | 02:57 PM
nhill2090's Avatar
nhill2090
What is actually happening is the butterfly valve on the exhaust back pressure valve closing, not the wastegate. It makes that sound because it closes off a majority of the exhaust gasses from exiting through the exhaust.
Old Nov 10, 2008 | 03:00 PM
megawatt00's Avatar
megawatt00
No need to aplolgoze friend! There is no ignorance here at all. We are here to learn, help, and to have fun!!!!
I'm really not to sure how it happens but your defination seems to be close to what I have heard. When the truck is cold the rpms kick up, EBV (exhaust back pressure valve) closes and the turbo tries to kick in some boost this causes a load on the engine and makes it heat up quicker.
I'm sorry I said waste gate before my mistake, I shold have said EBV. I was just looking at a part for my cabover. I apologize for the confusion.
Old Nov 10, 2008 | 03:01 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I love it when mine does that. Sounds like an F-14 on the flight deck....
Old Nov 10, 2008 | 03:03 PM
gappy's Avatar
gappy
The sound is cool but the first time it did that it worried me.
Thanks for the edgeekasion!!
Codymiller
Oct 8, 2018 05:26 PM
awillo0406
Jan 24, 2014 08:03 AM
spacquette
Jun 26, 2010 06:47 PM
automaticj5
1997 - 2003 F150
13
May 30, 2005 09:56 PM
tmryan362
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 16, 2004 01:59 PM
