I was driving my 66 down the street yesterday, and I went to shift from first to second, and it jammed. I thought at first I had jammed it between gears a common ailment to these old trucks. Specifically if the cab mounts are bad or if the shift rods are bent. I didn't think either of these were the case, and as it turns out I was right. The rear shift rod lost its clip, and came loose and was jamming the front rod. I was only a block from home and stuck in first so I limped it home slow, and pulled into the garage. Now I have bought 4 different E clips and they all look like the one I pulled from the front, but they fit like a saddle on a sow.
I am wondering for durability, and longevity, should I get snap rings?
i always thought hitch pins would work better than the stock clips, but i switched over to a floor shift before i got frustrated enough with the stock setup to try it.
Now I have bought 4 different E clips and they all look like the one I pulled from the front...How is it they are different, but they all look alike?
What was stock?
I would like to see how this turns out. I am assuming the shift rods look like mine and have a milled slot maybe 1/4" from the end of the rod for the clip?
Yeah, they do if I recall correctly. When I still had the 3 speed in mine I had a similar issue. Linkage was pretty much toast. I ended up just pulling the rods out, and fabbing some new ones out of bar stock, leaving the L end a little long, welding a washer on the inside, and drilling for a cotter pin on the outside.
Depending on how bad your linkage is, you may not need to do this. You may be able to just get away with drilling a hole in the rod for a cotter pin and using a washer. Mine was completely shot, so a new piece was in order.
My rods are in near perfect shape, other than the clips having a problem falling off. I looked close at them, and they are original, and they have the groove about a 1/4 inch from the end.
They are threaded shafts with a screwed on piece that has a nut on each side to keep it in place.
I thought about pulling the adjustment piece from the shaft, and taking it and finding the right clip, but I don't want to lose the adjustment. My truck shifts so nice compared to my last 3 on the tree I fear messing with it.
In that case I would just mark where the adjustment sits right now with a piece of tape, a sharpie marker may be good enough or just measure from a known point where the adjuster sits. Take it apart and to the hardware store. I think it will be a crapshoot for you to find the correct clip otherwise.
Like I said, mine was full on junk. And that was 16-17 years ago, heh. Hard for me to remember that far back.
Specifically if the cab mounts are bad or if the shift rods are bent or (and far more common), if the two rubber bushings in the column's selector levers harden up, then crack apart. **
There is only one type of clip that will work correctly, it's not a snap ring nor an E clip.
The originals are 'wavy' spring steel C clips with serrations on the inside: 379620-S100 / 3/4" O.D. ~ 9/16" I.D. / Ford just obsoleted this part.
You don't hafta go very far from your residencia to find these puppies. Just whiz on over to: O'MEARA FORD in Northglenn CO has 7 = 303-254-5050.
There are more elsewhere:
TOWN & COUNTRY FORD in Salida CO has 5 = 719-539-6633.
MANDERBACH FORD in Temple PA has 11 = 610-929-3683.
ROBINSON FORD SALES in Calexico CA has 13 = 760-357-3141.
CROWE FORD in Genesco IL has 14 = 309-944-2127.
GREEN SALES CO. in Cincinnati OH has 14 = 800-543-4959.
3 on the tree applications: 1965/72 F100/250 / 1966/77 Bronco / 1967/72 F350 / 1969/74 Econoline / 1973/79 F100/150.
-------------------------------------------------------------------------------------------------------------------- ** When the bushings that fit into the two steering column selector levers (spring clips-same location) harden up, then crack apart, the shift lever binds up between 1st & 2nd.
C5TZ-7343-A .. Selector Lever Bushing & Insulator Kit / Obsolete / Dozens still available from dealers/obsolete parts vendors.
I replaced my broken clips with E clips from my local Ace Hardware. I had to break out the middle part to get them to stay on (turn them into C-clips I guess) and with the size I bought, I have to use 2 clips at each end of the rod. So far I haven't had any problems with the clips themselves, just an adjustment to make since 1st and Rev are a pain to get into, however, 1->2 is silky smooth now.
