E4od clip found in pan
Old Jul 31, 2016 | 04:27 PM
wahlturfcare's Avatar
wahlturfcare
I found this today inside my pan on my e4od along with a couple valve body nuts.
I decided to inspect it after loosening my forward gears(barely had 1st) but perfect reverse. And was having a Hart time shifting from 1st to2nd(was jamming) and the shifter was loose to find the gears and would pop out of park and drive after the rebuild.
What could the clip be, and is my valve body maybe bad?
Old Jul 31, 2016 | 05:57 PM
Briansshop's Avatar
Briansshop
That looks like a piece of spring material from a sprag or one way clutch. Since you have no 1,2,or 3rd, I'd guess your OD OWC is not holding.
Old Jul 31, 2016 | 06:38 PM
wahlturfcare
Would it maybe be this clip where it says..or clip? As it does have a shift kit in it.
Old Jul 31, 2016 | 07:27 PM
Briansshop's Avatar
Briansshop
No. Those clips cannot fall/come out when the VB is installed,they are captured.
Old Jul 31, 2016 | 07:39 PM
wahlturfcare
Would maybe it not of been installed in the first place? I'd ask the business who rebuilt it but am getting no response back from them and they are never there when I show up.
Old Jul 31, 2016 | 07:42 PM
wahlturfcare
Also, pretty much all the valve body bolts were loose.
Old Jul 31, 2016 | 07:54 PM
Briansshop's Avatar
Briansshop
Sorry, but it sounds like you got a less than quality rebuild.
danr1
Jan 3, 2021 05:54 AM
Aj Hayes
Apr 6, 2016 05:57 PM
austin834
Jul 28, 2005 10:50 AM
tankhokie
Mar 21, 2005 07:05 PM
BobPringle
Mar 15, 2000 08:15 PM
