cold start?
Old Apr 27, 2011 | 04:19 PM
RickF350's Avatar
RickF350
cold start?
What would cause the engine to sometimes not start when cold on the first try, but fire up and run great on the second try?
Batteries and FICM are good.
Old Apr 27, 2011 | 06:22 PM
maxum96's Avatar
maxum96
Check for a HPOS (high pressure oil system) leak. I had a O-ring go out and it made it difficult to start my truck. Check the tech folder for the procedure to test your HPOS.
Old Apr 27, 2011 | 11:34 PM
RickF350's Avatar
RickF350
With warm oil the ICP reads (via scangauge) 0 cranking, about 580 when it starts and drops back to 0 over a few seconds after shut off. I'll check it cold tomorrow.
The strange thing is I can crank for 4 seconds or 10 seconds and not fire, then cycle the key again and it fires up within 2-3 seconds.
Old Apr 28, 2011 | 06:46 AM
bismic's Avatar
bismic
Could be several things. First - how do you know the FICM is good. That can not reliably be determined by a simple voltage check.
Old Apr 28, 2011 | 10:48 AM
RickF350's Avatar
RickF350
The original FICM had low voltage, so I Installed a new one from Swamps a few weeks ago.The new FICM helped with cold idle and MPG, but did nothing for the no cold start.
Swapped out the glow plug relay yesterday with a used one from an 03 Excursion. Probably take a few days before I know if it helped.
Old Apr 28, 2011 | 11:20 AM
RickF350's Avatar
RickF350
Truck started this morning on first try, took about 4 seconds, though.
ICP was about 1200.
Old Apr 28, 2011 | 12:29 PM
bismic's Avatar
bismic
Have you tried cycling the key (like you would when you change fuel filters) prior to actually cranking?
Old Apr 28, 2011 | 06:58 PM
RickF350's Avatar
RickF350
Well, not quite. Sometimes I cycle the key twice (wait for light to turn off each time) before cranking and it starts, but I don't do it all the time so it could be luck of the draw.
I've also had good luck if I wait for the fuel pump to shut off (about 20 seconds) before cranking, but a few times I still had to cycle the key twice.
I think for now I'll cycle the key once to see if the relay made a difference. If that fails to start it on the first try I'll start cycling the key twice every time I start it cold.
Also, this has been going on for a few years now, mostly during the cold months when temperatures drop below 40f at night.
Old Apr 28, 2011 | 07:30 PM
bismic's Avatar
bismic
Sounds like all you have is some air leakage into the fuel system.
Old Apr 28, 2011 | 08:21 PM
Misky6.0's Avatar
Misky6.0
Turning the key to "on" and waiting before "starting" seems to be
the key to me/my vehicle.
COLD engine: If I wait 15-20 seconds before cranking
it'll start up in < 1 second
HOT engine: IF I wait 10-15 seconds it'll start up < 1 second.
I climb in, turn the key to "on", close the door, then put on my
seat belt and it's about time to "start" it.
When the valet or the person moving it @ the Ford dealer
just turns the key to "start" w/o waiting - like it's a gas engine -
it'll crank for 4-5 seconds before it fires.
Wayner60
6.7L Power Stroke Diesel
Jan 22, 2015 04:13 PM
olyellow
Jun 23, 2014 11:46 PM
ejkoz
1997 - 2003 F150
Jan 26, 2010 05:26 PM
jcarter944
Nov 12, 2004 10:30 AM
bkles
Jan 5, 2004 02:44 PM
