stalls when cold
Old Jun 8, 2014 | 06:30 PM
olyellow's Avatar
olyellow
stalls when cold
04 f350 with a 6.0 started the truck when is was cold drove about a quarter mile then stopped at a stop sign and engine quit then when I tried to start it started right back up and was fine no codes
Old Jun 8, 2014 | 09:57 PM
78fordman's Avatar
78fordman
Check the icp voltage koeo. Check the ipr screen for damage. Did the glow plug light turn on after it died or just the oil and battery light?
Sent from my leash using IB AutoGroup
Old Jun 8, 2014 | 10:26 PM
texans's Avatar
texans
Also try wiggling the wires going to cam sensor (it's on the drivers side behind power-steering pump). I have seen a rash of them going bad lately. If it will start by moving that wire around then try and keep moving it and see if it will die again. If it will then you need a new wire harness.
Old Jun 9, 2014 | 05:11 PM
olyellow's Avatar
olyellow
stalls when cold
just before it quit the engine was surging,the glow plug light did not come on but when I tried to start it started right back up then was fine
Old Jun 9, 2014 | 05:12 PM
olyellow's Avatar
olyellow
I will check those other things to
Old Jun 17, 2014 | 05:55 PM
olyellow's Avatar
olyellow
the ipr screen I good the glow plug light does not come on also it surges for about 200 rpms but after you drive it for about 20 minutes it is fine
Old Jun 17, 2014 | 07:48 PM
78fordman's Avatar
78fordman
Do you have something to watch live data?
Old Jun 17, 2014 | 07:50 PM
78fordman's Avatar
78fordman
I had a 7.3 one time that did simular things, but also started hard sometimes. Turns out the Eot pigtail was having issues. It would loose connection and the Eot input went to like -140 deg and a split sec later it would read the norm. What the temp sensors close with live data and see if you see a jump.
Old Jun 17, 2014 | 07:52 PM
78fordman's Avatar
78fordman
Also try unplugging the icp sensor. It will go to a default value and see if the surging stops. Also look for oil inside the icp sensor connection.
Old Jun 17, 2014 | 07:56 PM
olyellow's Avatar
olyellow
I don't have anything for live data,I have watched the gauges when it acts up the temp gauge and oil gauges are normal and don't fluxuate I will check the icp tomorrow
Old Jun 17, 2014 | 08:05 PM
olyellow's Avatar
olyellow
thanks I will check those tomorrow and let you know what I find
Old Jun 17, 2014 | 08:17 PM
78fordman's Avatar
78fordman
The only accurate factory gauges are the speedometer and the door ajar light. The temp gauge will read normal between 170 and 220. Oil pressure just means you have more than 7 psi. If you have a smartphone get the torque app and a bluetooth obd2 adapter.
Old Jun 23, 2014 | 06:53 PM
olyellow's Avatar
olyellow
just wanted to thank everyone for the help got it running great what I did was removed the turbo took it apart and found the vanes were stuck then cleaned everything real good and put it back together now it runs great so thanks for the help
Old Jun 23, 2014 | 09:12 PM
texans's Avatar
texans
Good deal. Thanks for posting the solution. It's always nice to hear what fixed the problem. Most don't take the time to post solutions. Reps to you for that
Old Jun 23, 2014 | 11:46 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I wonder if you didn't fix something else in the process?
Cleaning the turbo shouldn't have any effect on an engine that dies.
Josh
kxriderforlife
Jan 17, 2017 06:06 AM
cuda66
6.4L Power Stroke Diesel
Feb 9, 2014 04:33 AM
King Kerosin
Dec 4, 2013 11:13 AM
F350mikey
Dec 23, 2012 09:19 AM
My4x4Toy
Feb 11, 2004 03:47 PM
