what is this seal?
Old Apr 27, 2011 | 01:35 PM
AbandonedBronco's Avatar
AbandonedBronco
Was just looking up timing covers for the 300. Most of them are dated 65-97. If the timing covers didn't change, I doubt the seals did either.
Old Apr 27, 2011 | 03:42 PM
BackWoodsGuy's Avatar
BackWoodsGuy
If you look back at the picture of patman247's timing cover then the inside of mine, you see mine does not have the internal lip to hold the seal.
Old Apr 27, 2011 | 08:47 PM
patman247's Avatar
patman247
I don't understand what the black rubber part on the inside seals to... what does it touch?
Old Apr 27, 2011 | 09:46 PM
BackWoodsGuy
It seals around the crankshaft.
Old Apr 28, 2011 | 12:09 AM
patman247's Avatar
patman247
ok.... on this motor that i have, the seal wont get anywhere near touching the crank, its still got like an inch on either side before it would touch the crank, ill snap some pics when i get home in the morning... grr im confused
Old Apr 28, 2011 | 12:49 AM
Rogue_Wulff's Avatar
Rogue_Wulff
It doesn't touch the crankshaft itself. It seals against the balancer/front pully hub assembly.
Old Apr 28, 2011 | 12:53 AM
patman247's Avatar
patman247
ok, makes so much more sense now!!! thanks for your help!
RacinNdrummin
2196
Oct 20, 2018 05:56 PM
Leichardti
Paint & Bodywork
Apr 3, 2012 06:35 PM
patman247
27
Jun 9, 2011 10:58 AM
builttoughf350
6.7L Power Stroke Diesel
13
Sep 27, 2010 01:17 PM
freeman666
Jan 6, 2009 01:45 PM
