HELP ME PLEASE
Old Apr 24, 2011 | 06:44 PM
bergy 2000's Avatar
bergy 2000
HELP ME PLEASE
I try to keep this short as possible. I have searched and read alot but need to confirm some things. I recently boght a 2000 v10 2wd Ex with 91k miles. I also bought a 32' travel trailer that weighs around 8000k lbs. I towed the camper over an 1hr with some big hills and never had issues. My scan gauge never read above 180. And that was only for a few min. After I got home and backed up my driveway which is was kind of steep, I noticed tranny fluid leaking around the rubber plug. It was enough to create a small trail up the drive. I stopped and put it in park and it cooled down nice and quickly to 145.
From what I have read the pump seal has leaked and should be replaced. I also should upgrade to the 6.0 cooler.
My questions are
If I do replace the seal and install the new tranny cooler will this happen again?
What are the best parts to replace the oem parts?
Where can I find the best prices on the parts and the cooler?
What would a shop charge me to replace the seal and supply and install the cooler?
Please help me fast, this is my primary tow vehicle and we have a full summer booked with camping trips. 3rd on in only 2 weeks.
Old Apr 24, 2011 | 09:31 PM
njneer1's Avatar
njneer1
common....if you were 4wd I'd say use low range....keep it fulll !!
Old Apr 24, 2011 | 11:26 PM
EXv10's Avatar
EXv10
It's common for them to overheat and leak in reverse when trailering and a new seal might do the same thing so I would just concentrate on getting a cooler large enough to keep the temps down before you change the seal. If it only leaks occasionaly in reverse I wouldn't worry about it.
Old Apr 25, 2011 | 05:28 PM
bergy 2000's Avatar
bergy 2000
update,
Today I cleaned the tranny fluid residue off the exhaust and pan and drove it around until I hit around 165 deg. checked for leaks and found none, Tranny level and color looks good too. I know it never got above 200 degrees, even when backing up,
so will I be ok if I just get a bigger better cooler?
I am looking for the best cooler I can fit.
What is the recomandations and where to find them?
Will the stock trans be ok to pull the 8000 lb camper about 12 times a year?
Most trips ar under 1 1/2 hrs away and very minor hills. The longest may be 2 - 2 1/2 hrs away and some minor hills. Mostly all highway.
The local trans shop which is not a chain, quoated me around $700 for the pumpseal and coverter bushing. The said if I need a new converter they start at $350.
What is the best converter for a stock v10 with 4:30 gears?
If it needs the converter should I just rebuild the whole trans while its down?
I need opinions.....Thanks
Old Apr 25, 2011 | 10:31 PM
EXv10's Avatar
EXv10
I think all the converters are the same for that tranny and I think putting it in reverse along with some heat increases the pressure at the front pump seal on that tranny. I wouldn't worry about it unless it starts going out. Maybe Mark (the late model tranny expert) will chime in. Start a new thread (TRANS PROBLEM......) and the late model trans pros will chime in. My trans days were over long ago.
Old Apr 26, 2011 | 06:37 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is your problem. No Excursion can tow an 8 million pound trailer
(k means 1,000, so 8000k means 8,000 * 1,000 = 8,000,000.)
Does your truck have a cooler in the radiator? If not, changing the radiator to one that does may be all you need. You could also change the aux cooler to one from a 6.0L truck. That's the best cooler you can get.
I don't know the best place to get the parts. There is a Viton seal available that will work much better than the stock seal. I don't know what shops in your area charge to do that.
JCs96
26
Sep 6, 2013 11:52 AM
bergy 2000
Apr 30, 2011 02:35 AM
bergy 2000
Apr 25, 2011 05:44 PM
DzelT
Mar 9, 2011 04:18 PM
6LPSD
Oct 28, 2008 04:44 PM
