Pump Seal.....I think... Please help
Old Apr 24, 2011 | 07:48 PM
bergy 2000's Avatar
bergy 2000
I will try to keep this short as possible. I have searched and read alot but need to confirm some things. I recently boght a 2000 v10 2wd Ex with 91k miles. I also bought a 32' travel trailer that weighs around 8000k lbs. I towed the camper over an 1hr with some big hills and never had issues. My scan gauge never read above 180. And that was only for a few min. After I got home and backed up my driveway which is was kind of steep, I noticed tranny fluid leaking around the rubber plug. It was enough to create a small trail up the drive. I stopped and put it in park and it cooled down nice and quickly to 145.
From what I have read the pump seal has leaked and should be replaced. I also should upgrade to the 6.0 cooler.
My questions are
If I do replace the seal and install the new tranny cooler will this happen again?
What are the best parts to replace the oem parts?
Where can I find the best prices on the parts and the cooler?
What would a shop charge me to replace the seal and supply and install the cooler?
Please help me fast, this is my primary tow vehicle and we have a full summer booked with camping trips. 3rd one in only 2 weeks.
<!-- / message -->
<!-- controls -->
Old Apr 25, 2011 | 05:44 PM
bergy 2000's Avatar
bergy 2000
update,
Today I cleaned the tranny fluid residue off the exhaust and pan and drove it around until I hit around 165 deg. checked for leaks and found none, Tranny level and color looks good too. I know it never got above 200 degrees, even when backing up,
so will I be ok if I just get a bigger better cooler?
I am looking for the best cooler I can fit.
What is the recomandations and where to find them?
Will the stock trans be ok to pull the 8000 lb camper about 12 times a year?
Most trips ar under 1 1/2 hrs away and very minor hills. The longest may be 2 - 2 1/2 hrs away and some minor hills. Mostly all highway.
The local trans shop which is not a chain, quoated me around $700 for the pumpseal and coverter bushing. The said if I need a new converter they start at $350.
What is the best converter for a stock v10 with 4:30 gears?
If it needs the converter should I just rebuild the whole trans while its down?
I need opinions.....Thanks
Mark Surks
Jul 23, 2012 10:15 AM
leiteralex
1997 - 2003 F150
Mar 19, 2012 08:50 PM
ffengine51
Texas Chapter
Sep 21, 2011 07:22 PM
daagitater
Jun 30, 2011 09:52 AM
eddierichards2000
May 17, 2011 01:03 AM
