05 engine erg/oil cooler, injector woes
hey guys posted some problems with my truck a few weeks back, with the oil cooler and fuel in oil. well the dealer i called today said oil cooler, egr cooler, egr valve and 5 fuel injectors need replaced now. i figured that the oil cooler would take out the egr cooler from being clogged? also but what would cause the injectors to leak? i change the fuel filters every 7000mi and use clean fuel and powerservice at every fillup why would they be leaking? bad seals, bad design or design warpage ? please help so that i can stop doing or start doing someting that will make the injectors last longer than 33k.
