HPX Question
Old Apr 23, 2011 | 08:15 PM
onelionhunter's Avatar
onelionhunter
HPX Question
For those that have the hard line HPX, will the turbo clear it, or does it have to be removed/reinstalled to swap turbos?
Thanks
Old Apr 23, 2011 | 08:42 PM
zx250's Avatar
zx250
Of the next Riffraff East
It should clear without any issues. It goes under everything.
Old Apr 23, 2011 | 08:48 PM
onelionhunter
Thanks
Thanks, going to be a new turbo by end of the week, just finishing up the carnage that started yesterday.
Old Apr 23, 2011 | 08:53 PM
rackhound's Avatar
rackhound
I just put one in last month. It will fit without removing anything but it takes some time.
Old Apr 23, 2011 | 08:54 PM
Bigcat350's Avatar
Bigcat350
I have it but I am not sure about taking the turbo off with it on. I like all the room I can get when taking the turbo out. So the HPX is easy to take off if needed so I would do that if needed.
Old Apr 23, 2011 | 08:58 PM
big poppa's Avatar
big poppa
Only thing I took out was the intake where the plenums hookup, makes for an easy install there. Easy cheesy..
Old Apr 23, 2011 | 09:08 PM
knuckleheadnut's Avatar
knuckleheadnut
i installed mine a couple weeks ago. the return line rests right on the side of the compressor housing, touches it for several inches. very tight fit at the JIC. route the line to get the most direct run at the return hole. there isn't a mm of slack to play with. be careful not to cross thread JICS and connectors. make sure you can tighten down several turns with just finger pressure before you wrench. take the "engine cover" bracket off of the HPOP to give you better acces to the passenger side fittings. loosening the fuel bowl bolts didn't really buy me anything b/c the fuel supply line will still be in the way. it's just a tricky bitch, but #8 definitely likes it. an extra hand (vice bungee) while installing the new FPR block would be a huge help. don't goof the spring and poppet or you'll end up doing it over. triple check for leaks.
Old Apr 23, 2011 | 09:24 PM
Bigcat350's Avatar
Bigcat350
Mike did you have the HPX when you changed turbos the last time?
Old Apr 23, 2011 | 09:27 PM
knuckleheadnut
sorry man- i was babbling about the FPr. HPx is a snap.
Old Apr 23, 2011 | 10:00 PM
big poppa's Avatar
big poppa
yep, but took it out also to install the 38R. This HPX was given to me, its a hard line shaped like a u in the middle, if you can picture that Eddy..,
Its all good, he'll know what to do when he gets his FRx..
deerslayer165
May 20, 2010 10:37 AM
Brown Falcon
23
Aug 20, 2009 02:36 PM
High Intentions
41
Feb 5, 2009 09:54 AM
Benny2002
Jun 25, 2007 11:52 PM
DragnBotm
45
May 8, 2007 12:49 PM
