HPX pictures?
Old Aug 18, 2009 | 04:38 PM
Brown Falcon's Avatar
Brown Falcon
HPX pictures?
Where does the HPX line go on a '95 truck? I can get it to fit on two plugs in between the turbo and the fuel filter housing.
Does it matter which two plugs you use?
Old Aug 18, 2009 | 05:14 PM
BlueMule's Avatar
BlueMule
You'll have to take the HPO supply line from the pump and move it to #4 and then run your crossover between #5 and #6
Old Aug 18, 2009 | 05:20 PM
Brown Falcon
Which plugs are which? I don't know which numbers are which...
Old Aug 18, 2009 | 06:01 PM
BlueMule's Avatar
BlueMule
Startin at the front 1,3,5,7 are on the right side and 2,4,6,8 are on the left. Your line should crossover just in front of the turbo and behind the intake plenums.
Old Aug 18, 2009 | 06:13 PM
BlueMule's Avatar
BlueMule
Which brand of HPX are you using, a hard line or steel braided?
Here's some pics of a TYMAR
Passenger Side w/ fittings
Driver Side w/ fittings
House Route - Front View
Hose Route Passenger Side View
Old Aug 18, 2009 | 07:31 PM
Brown Falcon
It's a hard line. My HPO supply line already goes to #4.
So it should be like this, going from #3 to #6:
Old Aug 18, 2009 | 07:50 PM
BlueMule's Avatar
BlueMule
Yes, it should be like that. BTW that's #4 on the drivers side and #5 on the other side.
Old Aug 18, 2009 | 07:56 PM
Brown Falcon
Ok. So I don't need to move any existing lines then. Just pull out the plugs and put the line in. Cool! Doing that tomorrow after work, too dark right now.
Old Aug 18, 2009 | 07:57 PM
BlueMule's Avatar
BlueMule
I just noticed you still have the red intake boot going to the turbo. Have you checked it lately? Most of them were replaced long ago because they didn't last. Take a look at the area where it clamps to the turbo. They usually rot and crack on the bottom and let unfiltered air into the turbo.
Old Aug 19, 2009 | 07:27 AM
Neal 97 250's Avatar
Neal 97 250
Here is a pic of mine:
Just remove the plugs and save them. Then install the HPX.
It is a good idea to take the plugs and replace the o-rings on them then keep them in the glove box in case you have a leak. It will get you home.
Old Aug 19, 2009 | 07:45 AM
Brown Falcon
I'll check that boot out. Thanks for the help!
Good idea. Thanks!
Old Aug 19, 2009 | 11:51 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I put the hard line on mine and for the #4 I had to use a small pry bar to move the oil line enough to get the fitting threaded in. That was the biggest pain of the whole install.
Don't be surprised if it cranks over more to start. Mine did but the more miles you put on it, it will eventualy start like it did before. I guess it just needs to bleed the air out of the pipe.
Old Aug 19, 2009 | 12:02 PM
Brown Falcon
Is there much of a difference between the hard line and the braided line? They both do the same thing. Is one better than the other?
I can't complain about the price I paid for mine though...
Old Aug 19, 2009 | 12:06 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
I think with the braided line it is recommended to replace every few years, the hard line is probably just watch for rust holes.
Old Aug 19, 2009 | 12:38 PM
79f-250custom's Avatar
79f-250custom
so can you make your own hard line? are the hook ups a double flared end?
thanks guys
Mitch
