White Smoke
Old May 4, 2011 | 03:14 PM
  #31
BLADE35's Avatar
BLADE35
have you checked the belt tensioner is the belt slipping on the water pump.
the only bad water pumps Iv seen leaked have you guys seen one with an internaly broke propeller or siezed pump witch should burn up the belt ???
you might want to consider a compression test if the other stuff checks out ok or before you tear it to far down
shivaskeeper
Jan 25, 2021 12:33 AM
1_BIGMOFO
Jun 3, 2011 08:06 AM
1_BIGMOFO
Apr 14, 2011 09:30 PM
rpage80
Nov 10, 2010 05:16 AM
ledheadz08
Jun 20, 2010 10:03 AM
