ECT EOT
Old Apr 19, 2011 | 06:37 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
From Bismic's spread sheet info:
Some say fan kicks on at 210, some say 215, others say 220. Full explanation: see cell to the right. Engine begins to defuel at 221 deg. The thermostat begins to open at about 190*F to 195*F and is not fully open until about 215*F to 219*F.
CELL TO THE RIGHT:
Engine temperature is not the only parameter that the PCM monitors to determine cooling fan operation. This is the reason that you will see some variation in engine temperature as it correlates to fan operation. The operation/description of the FSS (Fan Speed Sensor) from the PC/ED manual has a fairly good explanation as to how the system "thinks". This is not your traditional engine hits temp X and the fan clutch locks up. The fan speed sensor is a Hall-Effect sensor integral to the vistronic drive fan (VDF). The powertrain control module (PCM) will monitor sensor inputs and control the VDF speed based upon engine coolant temperature (ECT), transmission fluid temperature (TFT) and intake air temperature (IAT) requirements. When an increase in fan speed for vehicle cooling is requested, the PCM will monitor the FSS signal and output the required pulse width modulated (PWM) signal to a fluid port valve within the VDF. At least one person has seen the factory gauge go from normal to the "red" almost instantly. It happened at 248 degrees F.
By the way, my fan kicks in at 216*-218*. For what ever that is worth.
Old Apr 19, 2011 | 07:02 PM
i eat hybrids's Avatar
i eat hybrids
Thats when my fan kicks in to hahah. Teamks for recopyin that
My egr is plugged in btw
Monster Moovers
Nov 9, 2014 09:02 AM
Excurvelle
Oct 19, 2014 08:36 PM
Mark_in_co
Sep 15, 2014 04:12 PM
cornstar6207
Jun 19, 2014 03:01 PM
rattleNsmoke
Jan 7, 2012 10:57 AM
