Looks like the #6 glow plug went bad.is there a way to remove the harness without destroying it?. I priced a harness and it was 44 bucks,so if I do ruin it I'm not out to much,but would like to save the money if possible.any tips or advice is always greatly appreciated.
praying did the trick.anyone know the test procedure for the plugs?.i figured before trying to remove it id test it first.my luck, i'll be fishing out of the head when i go to take it out.do they get 12v from the controller?, and is there an ohm spec on them?.thanks in advance.......
hell they are cheap. and long so you wont have to fish it out. just take it out and replace it. takes a 10mm deep socket and they arent tight at all so dont torque it down when replacing it
