I had a couple of questions about ECT and EOT differences.
I recently had my EGR/Oil cooler replaced along with VC-9 flush 10,000 miles ago. I was towing my trailer yesterday, which is 20ft dual axle that prob weighed in at 5k. So my question is, my ECT and EOT dont go over a 10 degree difference no matter how hard you work her which is good. But yesterday while i was towing it was prob 50 degrees out so it wasnt warm at all. The temps were climbing It was about 210 ECT and 218 EOT on my insight CTS. Now i know the difference is normal. But how hot can those temps comfortably get? Is that a normal temp to be seen towing 5k @ 50 degree outside temp? At what point temp wise (ECT, EOT) does a 6.0 defuel?
It was straight highway. I need to find out at what temp EOT ECT wise that a 6.0 will defuel because you can set it as your max thresh on the Insight CTS.
When I pull my TT (7800#) on some of the hills, or even on interstate with a headwind my eot/ect's will reach into the 230 range. I would say your fine.
Ok thanks guys! I still have to figure out why my rigs throwing a P0528 code which is a no cooling fan circuit. I may have a bad fan clutch on my hands. I'll let y'all know if my temps change or if my clutch is bad or not. Either way gotta wait till pay day till a can buy the clutch so it may take a while unforunatley
Andriven once again thanks for the link. I printed out that post, cut it out and laminated it and put it on my fold down mirror lo or what ever you call it
Is your EGR valve plugged in? If not it has some control over your fan.
I am not sure when defueling happens with ect! Never defueled on me. I know I got stuck in february, with the radiator blocked, it was getting pretty hot (in the 240* range) and it never missed a beat. (I unblocked the radiator and it cooled in a hurry)
