93 rear axel the same?
Old Apr 12, 2011 | 10:37 PM
rideracelivemx7's Avatar
rideracelivemx7
i picked up a rear axel out of a idi 250 for dirt cheap. i just got it for the gears, 3:55s finally! the axel looks almost identical besides in the front it just looks a little off? im assuming the gears and what not inside are the same? hoping to just bolt in the ring and pinion and call it a day.
Old Apr 13, 2011 | 10:02 AM
dclack's Avatar
dclack
Changing a ring and pinion isn't a simple bolt in job. If you have the complete axle, then just swap the whole thing. That is a bolt in job.
The axles should be the same. Your 95 should have a Sterling 10.25 long pinion axle. They made a 10.25 short pinion but that should have ended in 92.
Old Apr 13, 2011 | 11:14 AM
rideracelivemx7
ive already fully built a dana 60 and that was easy! changing the ring and pinion will be a cake walk from what i usually do. but thanks for confirming the compatability
the 93 is an open diff and mine is a LS unit but its straight forward for the most part.
Old Apr 13, 2011 | 11:27 AM
arkredneck's Avatar
arkredneck
What about setting up the axle gear mesh all that?
Old Apr 13, 2011 | 01:14 PM
dclack's Avatar
dclack
Well, if you've built a D60, then this shouldn't be too hard, other than getting that crush sleeve to collapse.
Old Apr 13, 2011 | 05:06 PM
Krisx125's Avatar
Krisx125
What about backlash?
Bobird
Large Truck
Mar 17, 2014 05:04 PM
Go Zags!
Sep 25, 2007 11:47 AM
camarokid81
Apr 24, 2007 09:20 PM
hunter_firefighter
Sep 1, 2006 09:17 AM
