motor turns counter-clock wise?
Old Apr 13, 2011 | 12:21 PM
terrapin88's Avatar
terrapin88
I know the motor turns counter clock wise, but is that looking at it from the front of the motor, or the back? I'm turning the motor over with a ratchet to make sure I got all the fluids out of the cylinders after replacing my injectors.
Thanks
Chris-
Old Apr 13, 2011 | 12:43 PM
chicagodragon's Avatar
chicagodragon
looking at the front, engine turns clockwise
Old Apr 13, 2011 | 01:04 PM
terrapin88's Avatar
terrapin88
Thanks. I've been turning the motor counter clock looking at the front by using a ratchet on the alternator. So obviously I was turning it the wrong way. I wonder if that's why I didn't see any oil squirting out of the gp holes? I used a syringe to suck whatever fluids were in the driverside cylinders. But I only got about a shot glass worth of fluid out.
Old Apr 13, 2011 | 01:28 PM
Hussler's Avatar
Hussler
Pull off the single small wire on the fender starter relay. Using a jumper, jump that connector to the + side of the battery. Engine will crank and blow any oil out the glow plug holes.
Old Apr 13, 2011 | 01:30 PM
Hussler's Avatar
Hussler
Here is a larger photo of it ....
Old Apr 13, 2011 | 02:03 PM
Robbgt's Avatar
Robbgt
Never thought to do it that way Jim, good point. I usually just pull the IDM fuse and crank her over
Old Apr 13, 2011 | 02:18 PM
terrapin88's Avatar
terrapin88
thanks that's a great idea.
Old Apr 13, 2011 | 04:27 PM
Krisx125's Avatar
Krisx125
.......shouldnt it sqit out reguardless of the rotation?
Old Apr 13, 2011 | 04:47 PM
rideracelivemx7's Avatar
rideracelivemx7
it should, only way it will come out is if its filled to the cups and it will come out a little but a hand crank is no were near fast enough to blow that out, just put on a valve cover and crank it over, takes 20 seconds
Old Apr 13, 2011 | 06:02 PM
terrapin88's Avatar
terrapin88
That's the plan, bump it a few times. I am pretty sure I sucked most all of it out, but I want the extra security. Now if I could get 2 days in a row without rain, I might even get this done this month.
C-
Thisfordiskillingme
2004 - 2008 F150
Jun 18, 2024 07:41 AM
Greasemonkey76
1997 - 2003 F150
20
May 15, 2016 01:09 PM
lacyctdy
Nov 14, 2015 08:57 PM
HillBillyBuddha
Mar 5, 2014 12:19 PM
sa-jimd
Jan 29, 2014 05:41 PM
