alignment issue
Old Apr 12, 2011 | 10:08 PM
Slowroll90's Avatar
Slowroll90
alignment issue
hey folks,
so i recently replaced my tie rod ends ( outer ), in my drive and today i went down to get me an alignment. well they were able to do the toe in/out, but they said they were unable to adjust the camber. okay so I'm not surprised as i knew the stock set up wasn't adjustable. but here's the thing, the said that my camber is off, by nearly 1 degree.
is anyone surprised by this as I am or is this common.
i have a 94 2wd f150
Old Apr 12, 2011 | 10:38 PM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
Does it look like this /-\ ? If so, your front springs are sagging from age. You can fix this by installing new springs, leveling kit, or alignment bushing.
Old Apr 12, 2011 | 10:42 PM
old_lynrd's Avatar
old_lynrd
did they give you a print out of the alignment they performed? 1 degree off will wear tires slightly but they should have offered to install the cam ecentrics to make it adjustable
Old Apr 13, 2011 | 08:40 AM
turnkyle's Avatar
turnkyle
They should be able to adjust the camber or atleast point out the parts that may need replaced.
Tabaker
Apr 11, 2021 08:17 PM
94GreenTruck
1997 - 2003 F150
Dec 17, 2014 09:25 PM
zlusmc
May 19, 2011 01:19 PM
Slowroll90
Apr 14, 2011 03:37 PM
dfawvor
Jun 30, 2003 11:01 AM
