Camber problem
Camber problem
I have a 4" lift on my 90 f250. This was on there when I got the truck. The front wheels have a pretty noticeable positive camber. I talked to rough country and they said I need adjustable ball joints which are available at my local auto parts store. This doesn't seem to be all that true. Will an alignment fix this or what do I need to throw on there to fix my camber problems before getting an alignment.
There are adjustable shims available to correct camber on these trucks. If you have a 4" lift, you'll also need dropdown brackets for the I beam pivots-the shims won't correct it that much.
Steven Stocki
Feb 26, 2017 09:34 AM
Micheal G
Jun 18, 2016 07:33 AM
