hey folks,
so i recently replaced my tie rod ends ( outer ), in my drive and today i went down to get me an alignment. well they were able to do the toe in/out, but they said they were unable to adjust the camber. okay so I'm not surprised as i knew the stock set up wasn't adjustable. but here's the thing, the said that my camber is off, by nearly 1 degree.
is anyone surprised by this as I am or is this common.
i have a 94 2wd f150
Does it look like this /-\ ? If so, your front springs are sagging from age. You can fix this by installing new springs, leveling kit, or alignment bushing.
did they give you a print out of the alignment they performed? 1 degree off will wear tires slightly but they should have offered to install the cam ecentrics to make it adjustable
