Battery posts corrosion
Old Apr 12, 2011 | 02:50 PM
poocher pup's Avatar
poocher pup
Hello new to this part of the site but, my question is that my '04 positive battery posts will corrode within days of cleaning and coating them. Even went old-school and tried grease to no effect. Seems worse on primary battery than backup. If this has been asked before please forgive me as i searched and came up empty. Thanks in advance for any help.
Old Apr 12, 2011 | 06:30 PM
bismic's Avatar
bismic
Verify all the battery grounds are in good shape.
Charge the batteries and then load test them individually.
Do you have a voltage gauge to watch when the alternator kicks on? If so, what is it?
Consider testing the alternator as well.
Old Apr 13, 2011 | 08:28 AM
Cowboy65's Avatar
Cowboy65
Has this been happening for a while or did it only recently start?
Have you recently replaced your batteries?
From what I understand corrosion occurs due to acidic gas reacting with the lead in the battery post. A certain amount of gas is normally vented when the battery is in use, however you might be venting too much gas. Also sometimes there is a slight acid leak. The leak can be almost undetectable but can be enough to cause the situation you are describing.
Edit -- The red and green donuts that go under the cable connectors are treated with a chemical to slow the normal corrosion reaction.
Old Apr 13, 2011 | 08:40 AM
fast_st's Avatar
fast_st
Well, there are a couple things you can try. It could be that the primary battery is failing and getting overcharged/ofgassing. Check the water levels. If you can park the truck for a couple days, disconnect both batteries, clean all the cable and terminal ends with a terminal cleaner, rinse everything with a mild baking soda/water wash. Assuming both batteries are charged the same prior to starting, measure the voltage and or have a load test done on each. They need to be very close, 0.2 volts of each other. Apply a little green loctite around the joint between the case and battery post if leakage of acid is suspected. If the batteries are 2004, it may be time to head down and get a new pair of motorcraft batteries. (Ford parts have been super competitive on prices)
Old Apr 16, 2011 | 06:11 PM
poocher pup
Thanks i will check on batteries and alt.
nnero
2009 - 2014 F150
Aug 4, 2014 05:29 PM
66 twin i
General Automotive Discussion
Nov 22, 2006 07:11 PM
gamebore
Jun 18, 2006 11:20 AM
lakahahahman
Bronco II
Oct 21, 2003 09:32 PM
