Bronco II Ford Bronco II
battery keeps dying
Old Oct 20, 2003 | 05:12 PM
lakahahahman's Avatar
lakahahahman
battery keeps dying
battery trouble
bronco II
i had a guy replace the battery in my BII it is an 86 and he hooked the battery posts up backwords for a quick second then pulled it off right away
now my battery keeps going dead what could be wrong with this
some dip put the positive cable from the solonoid to the battery a black on
and the negative to the block a red on
why would someone do such a dumb thing
Old Oct 20, 2003 | 07:46 PM
Ken00's Avatar
Ken00
Either he damaged the battery or you have a short to ground. You need to put an amp meter in line with everything off and see if there is a draw.
Old Oct 20, 2003 | 08:42 PM
MJB's Avatar
MJB
or put a test light between disconnected negative terminal and battery post. If it lights, you have a draw. Also put a multi meter on your battery while the engine is running. You should see a reading near the 15 volt area on the 25 volt scale. But, if you ask me I think your alternator is toast. They have diodes which are one way check valves. Hooking the battery up backwards has put voltage through the diodes in the wrong direction burning them out.
Old Oct 20, 2003 | 10:27 PM
lakahahahman
when i got home from work i hooked my voltmeter up to the truck with the engine running and got a reading of 12.80 volts
then i shut the truck off came inside for awhile and grumped and griped at wife thinking i needed new alt
went out again and checked it with engine and everythig off and it read 12.47 volts
then i started the truck and it said i had 14.68 volts
how is this possible to change like that
Old Oct 21, 2003 | 12:11 PM
Ken00's Avatar
Ken00
It may have damaged the voltage regulator, I believe they are internal on the alternator.
Old Oct 21, 2003 | 03:04 PM
_rich_'s Avatar
_rich_
I think (I'm no expert) you should have around 12.8 volts with the engine off and around 14.8 or so with it running. If everythings working correctly, that should be very consistent.
Like Ken and MJB said, sounds like it's time to get the alternator tested. And get the battery cables corrected for color, or it's just going to happen again.
Old Oct 21, 2003 | 09:32 PM
MJB's Avatar
MJB
It used to be that a charge rate before internal regulators was 13.8 volts. The internal regulators are 14.5 volts. When ever you have a reading of 12 volts you are measuring the battery only. What I like to do is hook the volt meter up then start the engine. If no charging is happening the volt meter needle won't move off the present battery voltage reading. If the charging system is working you would see the volt meter needle jump up the the 14.5 volt area or near 15 volts. A for sure test would be to disconnect the negative battery cable while the engine is running. If the engine quits your charging system is not working. If the engine keeps running the charging system is good. This method will produce some engine surging as the computer has lost it's mind.
bkvanbek
Dec 28, 2013 09:29 AM
Ultraboy
Dec 16, 2013 09:16 AM
KMUL
Feb 11, 2012 05:27 PM
Milwaukee1979F150
Dec 12, 2011 03:36 PM
turnrjr
Oct 6, 2009 07:11 PM
