General Automotive Discussion
clean battery post
Old Nov 4, 2006 | 08:58 PM
66 twin i's Avatar
66 twin i
clean battery post
does anyone know of a good way to clean the green corrosion offf battery post?
Old Nov 4, 2006 | 10:09 PM
eigenvector's Avatar
eigenvector
A wire brush, a nylon brush, something like that. It's just lead sulfate, nothing toxic - unless you eat it
Always a good idea to wash the top of the battery off with a water and baking soda mixture. Just toss some baking soda in a bowl of water and mix it up with your finger. Then dampen a paper towel with it and use the towel to wash the top. Just don't touch both terminals at once
Old Nov 4, 2006 | 11:31 PM
bf250's Avatar
bf250
coke and a toothbrush!
Old Nov 5, 2006 | 01:15 AM
Traderjoe28's Avatar
Traderjoe28
You can touch both terminals at once without a problem. It's only 12 volts. You won't feel a thing, even if your hands are wet!
Mix a tablespoon of backing soda in an 8 ounce glass of warm water. Remove the battery from the car, then dribble the solution over the top of the battery around the terminals. When all the fizzing has stopped, rinse the battery top with clear water and dry with a paper towel. Clean the posts with a battery post cleaner, available at any automotive parts supply house for about $1.00. Use the wire brush that's part of the post cleaner tool to clean out the female terminal ends on the connecting cables in the motor compartment. You want a good, clean mating surface of both the post AND the connector when you tighten the connector. A poor connection will not only starve your starter of current when you fire up the engine, it also prevents the alternator from being able keep the battery fully charged.
Old Nov 5, 2006 | 07:43 AM
66 twin i's Avatar
66 twin i
Thanks for the info i will give it a shot.
Old Nov 6, 2006 | 12:56 PM
jim henderson's Avatar
jim henderson
DO NOT let the baking soda solution get into the battery caps tho. It will deactivate or weaken the cell. Do spray down the sheetmetal under the battery with the bakingsoda and rinse well.
YOu might use a No-Corrosion donut or some spray after wards.
Good Luck,
Jim Henderson
Old Nov 6, 2006 | 08:18 PM
Code3's Avatar
Code3
I prefer the Coke and wire brush method. After that, spray some of that blue crap on the terminals to prevent corrosion. Coke works on everything, even takes hydraulic fluid, jet fuel, and other mechanical crud out of clothes. Pour a Coke out in your washing machine when you do laundry and all the nasties come out.
Old Nov 6, 2006 | 11:17 PM
thefarelaneman's Avatar
thefarelaneman
Baking soda solution works. I also like to remove the cable connectors and "scuff" the inside with some sand paper and same with the terminal, Then apply a coat of electric grease and secure them tight. Some people like to coat the whole connection is heavy grease. We did it to schools buses because we didnt have time to keep re-fixing a poor connection.
Old Nov 7, 2006 | 02:58 PM
Steina's Avatar
Steina
CO River Rat
Make sure you wear safety glasses when you're wire-brushing that battery!
After you get 'er clean, install a pair of those red/green chemical felt washers before putting the clamps back on; they'll help keep the crud from reappearing.
Steve
Old Nov 22, 2006 | 07:11 PM
crerar's Avatar
crerar
If you drive older vehicles (and/or associate with those who do), and may sometimes encounter (or harbor) a battery of less than impeccable hygeine, one of those $1 (maybe $2.00) post cleaners traderjoe28 mentioned above can be a real handy thing to keep in the glove compartment - little wirebrush christmas tree to clean inside clamps and a wire-lined hole to shine up the posts in a hurry can sometimes make the difference between click-click-click and rrr-rrr-vroom!
nnero
2009 - 2014 F150
Aug 4, 2014 05:29 PM
flo
Aerostar
Nov 30, 2006 09:05 AM
SMarquez
Jun 14, 2005 10:26 AM
76supercab2
Electrical Systems/Wiring
Apr 20, 2004 11:50 AM
