Battery terminal cleaning question
Old Jul 28, 2014 | 07:50 AM
nnero's Avatar
nnero
I noticed some corrosion on my battery terminals this weekend. Is there anything I need to know before I disconnect the battery to clean the terminals and battery posts? Will I have to pair my phone with Sync again? Thanks
Old Jul 28, 2014 | 11:27 AM
royb's Avatar
royb
no you will be fine
Old Jul 30, 2014 | 09:40 AM
Truckpilot1329's Avatar
Truckpilot1329
I've seen shops attach 12 V cables to battery cables before they're removed, so
power is still being applied to them while they're off.
Should be easy to do, using jumper cables attached to another vehicle.
Old Aug 2, 2014 | 11:10 PM
Papa Tiger's Avatar
Papa Tiger
U can get one inexpensively that plugs into the cig lighter to keep things saved while you disconnect the battery.
Old Aug 3, 2014 | 10:53 AM
gDMJoe's Avatar
gDMJoe
Once you've got them cleaned ...
  • add anti-corrosion battery post washers
  • then ... spray the posts with silicone at (say) each oil change interval.
Both are inexpensive prevention measures
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old Aug 3, 2014 | 01:45 PM
Tedster9's Avatar
Tedster9
Another thing to look at - while you're at it - have you thought about where the negative cable actually goes? You should - it's connected to the engine block, as the main ground point for everything, and subject to all the corrosion and current-robbing effects that the battery end of the cable is as well.
It pays to disconnect, clean down to bright bare metal and then treat with a corrosion preventive compound like NO-OX-ID "special", a conductive grease long used for telephone switch gear, buss bars &c in difficult environments. If the cables are more than say, 15 or 20 years old it's best to replace them especially if the equipment or truck was stored outside.
Sent from my iPhone using IB AutoGroup
Old Aug 4, 2014 | 08:49 AM
nnero's Avatar
nnero
Thanks. The corrosion was worse on the positve cable. I got a kit at NAPA that included brush, cleaner, protective spray, and the washers. I will check the ground at the engine as well.
Old Aug 4, 2014 | 05:29 PM
tvsjr's Avatar
tvsjr
Or swap to a AGM/SLA style battery... no outgassing = no corrosion.
Rockinfigs
All Things Towing
Jul 27, 2023 10:55 AM
Tony_C
Dec 13, 2011 11:53 AM
hojolabo
General Automotive Discussion
Oct 21, 2008 07:13 PM
76supercab2
Electrical Systems/Wiring
Apr 20, 2004 11:50 AM
couleeman
Dec 10, 2003 08:54 PM
