Coolant Filter Change
Old Apr 23, 2011 | 04:49 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
Originally Posted by MisterCMK
How did you cut that filter open? If you used a saw it can make things look worse than they actually are.
used my sawzall.....never saw metal shavings look like mud....
Old Apr 23, 2011 | 04:55 PM
Franko72's Avatar
Franko72
Molon Labe
The Napa 4070 filter is a non-charged replacement filter for that Baldwin FYI
That was my next question...thanks.
I have one more....What does non-charged mean anyway
Old Apr 23, 2011 | 05:11 PM
Journeymaaann's Avatar
Journeymaaann
When everyone was using the original coolant one had to check the SCA levels & recharge the system. Someone came up with the idea of having the sca's in a filter so the correct potency could be maintained. That filter would be know as a 'charged' filter. The same filter with no sca's in it was 'uncharged'. In either case it was up to you to determine & maintain the correct sca level. That all changed when ELC or Extended Life Coolant arrived. No sca check needed. For me that was part of the reason I switched. Hope this helps.
Old Apr 23, 2011 | 05:12 PM
MisterCMK's Avatar
MisterCMK
Nope, I am not saying that it does. All I am saying is that if you are looking for sand particulates or things like that the metals shavings will distort things.
That being said I just changed my coolant filter after 10k miles on my truck and it sure was nasty how much sand and crap came out.
Old Apr 23, 2011 | 05:13 PM
MisterCMK's Avatar
MisterCMK
Non-charged mean that it does not have the additive pellets in it.
Old Apr 23, 2011 | 05:50 PM
Franko72's Avatar
Franko72
Molon Labe
Thank you both I keep learning everyday.
Old Apr 23, 2011 | 06:13 PM
CPUNeck's Avatar
CPUNeck
When you first install the filter, you'll get "sand"... remnants from the casting. What I'm seeing in the OP's picture appears to be "fall out" when two incompatible coolants are mixed.
Had this happen to me some years back, couldn't even see the pleats of the filter. Straight up snot looking stuff. I switched from green to ELC, and didn't do a good enough job flushing the system (read almost impossible to get all the old out)
Old Apr 23, 2011 | 07:01 PM
MisterCMK's Avatar
MisterCMK
You will also get pieces of sand and casting stuff as time goes by because it breaks off from the heat cycles as I understand it.
Old Apr 23, 2011 | 07:06 PM
big poppa's Avatar
big poppa
This was my first filter change and what came out of it my setup
Old Apr 23, 2011 | 07:39 PM
CPUNeck's Avatar
CPUNeck
Mike, I'll bet your stomach was a little squeamish when you was that... Mine was. I didn't take any pics, it was a WHILE ago. But I do still have a pick of the fall out.
So after that filter, no more fall out. I changed them @ 3 months for 6 months until I was satisfied.
Old Apr 23, 2011 | 08:08 PM
big poppa's Avatar
big poppa
That is nasty, thanks for posting brother, I'm sure people here would want to see what it looks like..And your right, not only was my stomach turning, I was upset that I didn't know about this filtering setup when I bought my truck new, prolly would have protected my waterpump seals from the start. I got a 161,000 on my stock W-P so only time will tell after about 60,000 with the filter setup so we'll see.
Aaron-71
237
Jan 24, 2018 08:32 AM
hotnanas
Jun 17, 2016 12:14 PM
82F100SWB
19
May 7, 2016 12:47 AM
Aaron-71
123
Jul 7, 2015 05:37 PM
indyF-350psd
16
Jun 26, 2012 08:21 AM
