Coolant Filter Change
Old Apr 5, 2011 | 07:35 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i know this has been shown before but seeing as how i changed a water pump 2 years ago and then again last week i figured i would post up my findings. 2 years ago i changed the w/p and added my coolant filter. 3 months after adding the filter i changed the filter out to a new one per the interval instructions. i figured since i had new coolant it wouldnt be all that dirty. well after last weeks w/p change i changed the coolant filter again and then cut open my old filter and this is what it looked like:
this is the sediment that came out of the filter by just turning it upside down. the picture doesnt do it justice its a lot dirtier in person...
and here is the old filter internals:
pretty nasty huh?
Old Apr 5, 2011 | 07:59 PM
big poppa's Avatar
big poppa
Awesome pics Bill and thanks for sharing. Although its all good some might think (hypothetically speaking) We're all on a mission for people to go out and make their own coolant filtration system or just buy one, either way, the filters work and its been proven, over and over again.. Thanks for documenting, might save a water pump or two. Reps when I can Bill, just tried
guitarpicr's Avatar
guitarpicr
Wow -That is amazing- Reminds me I need to change mine out.
Old Apr 23, 2011 | 12:06 PM
Franko72's Avatar
Franko72
Molon Labe
I just installed the coolant filter kit today. I'm curious what I find in my first filter.
Old Apr 23, 2011 | 01:51 PM
big poppa's Avatar
big poppa
I actually went about 8 months maybe, give or take IIRC on the first filter swap even though Bob at (DS) said 3 months, your call really Franko.. I went by the flow restriction theory, when I seen the coolant was getting slower than normal flow into the degass bottle I changed mine.
Old Apr 23, 2011 | 02:12 PM
cj45lc's Avatar
cj45lc
That's pretty much the same thoughts I had with mine Mike, I just kept looking at the flow back into the bottle. I changed my 1st filter at about 6mos iirc & I believe I run that 2nd filter for right at a year then put a new filt when I switched to the ELC coolant. I thnk I'll just put a new filt on every year unless I hear something different.
Old Apr 23, 2011 | 02:22 PM
PwerStroke99's Avatar
PwerStroke99
Thats what i did too Mike
Old Apr 23, 2011 | 02:27 PM
Franko72's Avatar
Franko72
Molon Labe
Good info Mike, I'll keep an eye on it. I also installed the ball valves to shut it off, just in case I'm filterless.
Old Apr 23, 2011 | 02:32 PM
big poppa's Avatar
big poppa
Nice pics Frank.....I like the new housing.
Old Apr 23, 2011 | 02:44 PM
Franko72's Avatar
Franko72
Molon Labe
Thanks Mike, i also installed an HPx.
I got everything from a FTE brother who sold his truck.
Old Apr 23, 2011 | 03:13 PM
big poppa's Avatar
big poppa
Can't beat that, nice...
Old Apr 23, 2011 | 03:14 PM
MisterCMK's Avatar
MisterCMK
How did you cut that filter open? If you used a saw it can make things look worse than they actually are.
Old Apr 23, 2011 | 03:29 PM
cj45lc's Avatar
cj45lc
Hey Frank if you did happen to run it until the filter got completely blocked it's not going to have any effect except not filtering. Another thing I heard to do is feel the filter after the truck is warmed up & if the filter is not as warm as the rad you know no coolant is going thru it, you prob already knew that.
Old Apr 23, 2011 | 04:16 PM
Franko72's Avatar
Franko72
Molon Labe
Actually I did not know that, but it makes perfect sense. So thanks for bringing it to my attention. I'll keep it in mind.
Old Apr 23, 2011 | 04:44 PM
MisterCMK's Avatar
MisterCMK
The Napa 4070 filter is a non-charged replacement filter for that Baldwin FYI
