hey guys my ABS light just came on today, is there an exact reason for it coming on, i just don't wanna replace something and not have that be the problem?
Hi, we have the same problem with abs light,but my son put a f-350 dually under his f-250
Light comes on now did not before rear end change,did rear brakes at same time,changed sensor on rear end from original rear end no change,bled brakes several times,thanks
Low fluid is supposed to turn on the abs light and the red brake light. Not just one of them.
I'd suggest getting the code flashed off and going from there so you aren't replacing unnecessary parts. It's pretty easy. There is a wire that you ground and the code flashes on the abs light. The wire is in different places on different trucks and the procedure is different on different years too so I' not sure about yours but you don't need a scanner for it. There are too many things that can turn on the abs light though to just start guessing at parts.
