1997 explorer
Old Nov 29, 2014 | 10:30 PM
njtinman2's Avatar
njtinman2
1997 explorer
i just bought a 97 explorer and the abs light is on is there a way to pull the codes without an abs scanner?
Old Nov 30, 2014 | 11:03 PM
shorod's Avatar
shorod
Nope, you'll need an ABS capable scan tool to retrieve the ABS system diagnostic codes. Some of the chain auto parts stores do sell a consumer grade ABS and SRS enabled scan tool that might work for your 97 Explorer.
-Rod
Old Dec 8, 2014 | 05:03 AM
njtinman2's Avatar
njtinman2
changed the vss in the rear axle and that fixed it
Old Dec 8, 2014 | 05:05 AM
senix's Avatar
senix
how did you determine that was need to be changed (VSS)?
c-dub
Apr 1, 2006 08:00 PM
