Low Voltage
Old Jul 12, 2011 | 09:03 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Low Voltage
When I stated her up yesterday, she was showing low voltage. I just replaced the batteries a couple months ago and it doesn't appear that the belt is slipping. I suppose I'll have to get the alternator bench tested. How do I check it at home?
Old Jul 12, 2011 | 09:32 PM
farmert's Avatar
farmert
If you have a multi meter, set it to 20 volts DC. Touch the red probe to the bolt where the big red wire attaches to the back of the alt. The black probe goes to the battery ground. You should read at least 13.5 volts. Be careful not to touch both the alt. case and the bolt at the same time with the probe. Big sparks happen if you do.
Old Jul 13, 2011 | 07:32 AM
Fullcrew7.3
That's kinda what I thought, but electrical things are not my forte. Thanks Tom.
Old Jul 13, 2011 | 09:38 AM
RRranch's Avatar
RRranch
If it is low then first verify that all of your engine and frame grounds are clean and tight. Then just go get another FORD voltage regulator. It's on the back of the alternator and I think it was just a couple T15 screws holding it on. It contains the alt brushes and the regulator. It's easy to replace and a LOT cheaper than an alternator. I've never replaced a Ford alternator before.
Old Jul 13, 2011 | 08:32 PM
Fullcrew7.3
Cool. Thanks for the info
xaviar
May 8, 2015 07:01 PM
Jjk27
Oct 23, 2014 05:36 PM
Polkster
Mar 24, 2014 07:40 PM
btypd
Feb 10, 2014 11:43 PM
Number21
Nov 4, 2013 10:09 AM
