d50 spindle nut socket...?
Old Apr 5, 2011 | 06:35 AM
Neal 97 250's Avatar
Neal 97 250
Originally Posted by rideracelivemx7
ive actually never used hub sockets, a screw driver and a hammer has worked for me the past 2 times!
X2. Me too. I have had this truck for 14 years and never needed/found the socket. I always used a small screwdriver, small hammer to tap it loose and a circuit tester to spin it off (because it has a thin tip that fits in the holes). Never have I broken an axle. Or ever had any issues. I had the factory auto hubs and they are still working like the day they were new. If you know how to tighten a spindle nut properly that is all you need.
Originally Posted by superduty4x4
How about for a D60 fellas? It's ball joint time.
Same situation. D50 and D60 used the same nuts, calipers, pads, bearings, etc.
Old Apr 5, 2011 | 07:19 AM
rideracelivemx7's Avatar
rideracelivemx7
Good to know someone has the same method as me! Lol and I broke the stub shaft next too the pumpkin, 1000lb motor+ 800lbs of tq+ 4lo= boom!
Old Apr 5, 2011 | 07:20 AM
Talyn's Avatar
Talyn
I was teasin Steve. =)
Old Apr 5, 2011 | 08:51 AM
superduty4x4's Avatar
superduty4x4
Well I may just give it a shot, thanks.
Old Apr 5, 2011 | 09:04 AM
Cuda_jim's Avatar
Cuda_jim
I've used the screw driver method in the past but was worried about not getting the outer lock nut tighten to spec (160-205 Lb-Ft). Nothing ever came loose but I bought the sockets anyway.......it just makes things easier.
Old Apr 5, 2011 | 10:14 AM
redman84's Avatar
redman84
Originally Posted by dclack
Somebody didn't read the Warn install instructions...
I don't doubt that a bit! Especially after seeing the work elsewhere on that truck...
Old Apr 5, 2011 | 12:25 PM
Neal 97 250
I agree. I wouldn't use the screwdriver on the double nut style. You just can't get enough torque in there.
Old Apr 5, 2011 | 08:00 PM
Talyn's Avatar
Talyn
Screwdriver just is the in a pinch way.
If thats the way you want to do it otherwise, thats your choice.
But I would never suggest such a method to anyone unless they were in dire need.
Talyn's Avatar
Talyn
Romanova
Dec 7, 2015 03:54 PM
Mustangking1
Dec 4, 2014 07:07 PM
TyBragg
19
Oct 26, 2012 06:26 AM
AllaboutMPG
Feb 14, 2012 06:52 PM
snakedoc
Apr 24, 2011 10:45 PM
