D60 Spindle Nut Size?
Old Oct 23, 2012 | 08:53 AM
TyBragg's Avatar
TyBragg
Does anyone know the size of the spindle nut on the D60's? (I'm wondering if they're all the same) This would be for my 97 350. I did some searching on here, but can't seem to find much confirmation of the size socket that I'll need. The spindle nut on my 250 (yes, 250) is the 3 piece kind with the little lock washer with all the holes in it in between the two nuts. The spindle nut socket for that one has the prongs that stick out and go in the grooves on the nut . On my 350, it looks like a regular hex head nut (no slots or grooves). I'm trying to find the size of that hex head spindle nut without having to buy a few different sockets to see which one fits. Anyone know right off? Thanks.
Old Oct 23, 2012 | 03:24 PM
ReBilld's Avatar
ReBilld
Hold your left hand up as though you are looking at the back your hand. Bend your pointer finger at the middle knuckle to a 90 degree angle. Take note of the distance between the tip of your pointer finger, and the tip of your thumb.................bout that big.
Old Oct 23, 2012 | 03:33 PM
fordpride's Avatar
fordpride
That's funny Bill
Old Oct 23, 2012 | 03:35 PM
ReBilld's Avatar
ReBilld
Originally Posted by fordpride
That's funny Bill
I love messing with him!
Old Oct 23, 2012 | 03:43 PM
lud04X's Avatar
lud04X
the one i bought for my 1997 f350 is1/2 in drive 4lug internal 76mm x 80mm. Got it at oreillys.
Old Oct 23, 2012 | 05:10 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
1/2 dr.4 lug internal 75mm X 80mm locknut socket.
Dana 50 front axle.
(tool sticker says 85-95)
GreatNeck #33625966
sold at autozone.
D50 uses D60 outer parts.so spindle nut socket will be the same.
very strange your reporting that your f250 4x4 doesn't share the same spindle nuts as your f350 4x4.maybe you need to look again?
maybe they did something strange in '97 im unaware of too.
edit,oh maybe you still have those stupid auto lockers on your 250 (i can't believe those lasted! you must not use 4wd often lol.)
Old Oct 24, 2012 | 06:36 AM
TyBragg's Avatar
TyBragg
Dana 50 front axle.
GreatNeck #33625966
sold at autozone.
Definitely not the same. No auto lockers on either truck. Both are manual hubs. Like I said, the 250 has the 3 piece nuts - the one with all the studs on it, then the washer that fits into the key way that has all the holes in it that lines up with said studs on first nut, then the outer nut that tightens down on the first two which has notches cut out in it, and the spindle socket has the notches to match. The 350 one looks like a regular hex nut. Haven't taken it off yet too see it completely (hence this thread to find the size of the nut).
Old Oct 24, 2012 | 06:45 PM
C350CREW's Avatar
C350CREW
Hey Tyler,
Mine is a KD brand, #3456, Steves auto parts, $25. Package says it is a 2-3/4".
You are welcome to use it, wont need for a while. I can put it in the truck and give it to you tomorrw after work.
Randy
Old Oct 24, 2012 | 07:47 PM
TyBragg's Avatar
TyBragg
Originally Posted by C350CREW
Hey Tyler,
Randy
Thanks Randy! I appreciate the offer, and thanks for the info. But I think Bill was wanting to get one anyway so he had one. I'm just seeing if anyone knows the size. I told him I was gonna buy one, and he said "Don't bother, I'll get one so I have it." I said "even if I buy one." He said "Yeah." I'll probably donate it to his shop to help repay some of the dues I owe him!
Old Oct 24, 2012 | 08:14 PM
C350CREW's Avatar
C350CREW
You getting ready to work on the front axle or just looking for info? I just put ball joint on one side and need to do the other on the green Ford. Red one needs spring bushings replaced all around and shocks. Too much to do, not enough time.
Old Oct 24, 2012 | 08:24 PM
ReBilld's Avatar
ReBilld
Hey Randy! I love the avatar!
Old Oct 24, 2012 | 09:26 PM
C350CREW's Avatar
C350CREW
Thanks, thought I needed to spruce up my ID a little. This was the best one I found. Got a couple others that are good, not sure if they are appropriate though. Dont want to get kicked out of here. That pic is actually a sticker you can buy.
Old Oct 24, 2012 | 09:37 PM
ReBilld's Avatar
ReBilld
I cracked up when I saw that! I need to get me one of those stickers.
Old Oct 24, 2012 | 09:42 PM
ReBilld's Avatar
ReBilld
Check out this thread Randy....https://www.ford-trucks.com/forums/1...y-flatbed.html Maybe you could shoot Chad a PM if you're still thinking of going to single rear wheel.
Old Oct 24, 2012 | 09:46 PM
C350CREW's Avatar
C350CREW
Yeah, I saw that. I will contact him to see if he would be interested.
Gonna hit the hay. Us old folk need our beauty sleep.
