d50 spindle nut socket...?
Old Apr 3, 2011 | 10:11 PM
Talyn's Avatar
Talyn
Okay I had a search feature fail.
What socket am I supposed to buy?
2 or 3 packages say they are the right socket.
I've seen it on here so many times. I duno why its not showing up in searches.
d50 socket?
which is the right one?
Old Apr 4, 2011 | 07:13 AM
Cuda_jim's Avatar
Cuda_jim
It's going to depend on what's inside you axle. Have you removed the cover to take a look? It can be any one of these:
Four prong internal tooth OTC , 205-192 Wheel Hub Nut Socket - T83T-1197-B
2-1/2" Rounded Hex OTC , 519097-5 Wheel Bearing Locknut Socket T95T-1197-A 2-1/2" Rounded Hex
2-3/4" Rounded Hex OTC , 519097-4 Wheel Bearing Locknut Socket T95T-1197-B - 2-3/4" Rounded Hex
Old Apr 4, 2011 | 10:50 AM
Talyn's Avatar
Talyn
Oh damn, They really used that many different spindle nuts? What a pita.
Old Apr 4, 2011 | 10:51 AM
Talyn's Avatar
Talyn
Now, how come you dont see the second and 3rd link ones at the store?
Or instead of making it a socket, they are doing the teeth/prong method to grab the sides?
I was looking for ones like the second 2 links there.
Old Apr 4, 2011 | 11:07 AM
redman84's Avatar
redman84
William, without a doubt mine uses the 3rd link Jim posted. Truck in my sig w/ D50. It can be had at any auto parts store. Look for the rounded hex spindle sockets. Should say 2 3/4" 6R.
Old Apr 4, 2011 | 11:18 AM
Cuda_jim's Avatar
Cuda_jim
The links are working for me??
The reason I said look inside...... is you never know what you're going to find, the PO may have changes the nut or lock-outs.
Old Apr 4, 2011 | 11:21 AM
Talyn's Avatar
Talyn
thanks Jim and Jacob.
I think i'll just pay the 60 for the rental cost, and buy the correct socket when i'm done.
Old Apr 4, 2011 | 02:16 PM
dclack's Avatar
dclack
Auto hubs use the 2 3/4" hex socket and manual hubs use the "four prong internal tooth" socket. I've had both sockets and they only cost about $20 each at Autozone.
Old Apr 4, 2011 | 02:27 PM
Talyn's Avatar
Talyn
yeah, I got man u els.
Thanks Dclack
Old Apr 4, 2011 | 02:36 PM
dclack's Avatar
dclack
Thanks Dclack
Then you need the four prong socket. There will be a lock nut, lock washer, and retaining nut. If you have a chiltons manual it will tell you how to torque the nuts.
Old Apr 4, 2011 | 03:18 PM
redman84's Avatar
redman84
Just a heads up. The 95 parts truck I had with Warn manual hubs on te D50 used the same 2 3/4" rounded hex head socket. Had the exact same nut as my auto hubs. Doesn't mean it was correct but that's what was in there.
Old Apr 4, 2011 | 05:44 PM
dclack's Avatar
dclack
Somebody didn't read the Warn install instructions...
http://warn.iwebcat.com/_Members/lookups/partdetail.asp
"WHEN REMOVING A WARN AUTO HUB (1995 & LATER FORD OEM, OR A WARN AUTO HUB RETROFITTED ON FORD OR GM VEHICLES), CONVERSION KIT No. 32721 MUST BE INSTALLED."
Old Apr 4, 2011 | 06:09 PM
rideracelivemx7's Avatar
rideracelivemx7
ive actually never used hub sockets, a screw driver and a hammer has worked for me the past 2 times!
Old Apr 4, 2011 | 06:46 PM
superduty4x4's Avatar
superduty4x4
How about for a D60 fellas? It's ball joint time.
Old Apr 4, 2011 | 07:02 PM
Talyn's Avatar
Talyn
Thats probably why you broke your axle. =)
yeah, ball joints here too.
