replacing an injector today
Old Apr 3, 2011 | 03:06 PM
BLADE35's Avatar
BLADE35
you will be fine its not bad job
Take your time keep it clean
Old Apr 3, 2011 | 05:47 PM
00buck75's Avatar
00buck75
ok,
back together. started up rough, now running smooth, but hear a hiss from the fuel filter area. Also long crank still after a few starting cycles, but then fires with authority.
How long does it take to get all air out?
Should I take it for a spin?
am I concerned about nothing?
Old Apr 3, 2011 | 06:02 PM
cartmanea's Avatar
cartmanea
It can take a while to get all the air out of the HPOP system. Take it out and do some WOT runs to work it out quicker.
Old Apr 3, 2011 | 10:37 PM
00buck75's Avatar
00buck75
Thanks to all that gave advice.
I gave every one reps.
Went pretty well.
Truck idles, runs, & sounds so much better. You don't realize how bad something was until it is fixed.
The injector I pulled was replaced under warranty and was never installed correctly.
It had a broken plug that wouldn't properly plug in to the wiring harness.
After out of the truck and laying on the work bench, you could see how the pins in the plug were black from arcing because of the loose connection.
Have to pick up an o-ring for the plastic ccv elbow that fits in the valve cover. It was in 3 pieces when I removed it. Wrapped electric tape around it after I put in back in the valve cover. It is a band aid till I pick up an o-ring at a dealer.
Old Apr 3, 2011 | 11:00 PM
BLADE35's Avatar
BLADE35
Went pretty well.
thanks for the reps
I had the same thing broken o-ring on the ccv elbow/valve cover
good to hear all is good
Old Apr 3, 2011 | 11:04 PM
00buck75's Avatar
00buck75
someone now needs to explain the "blue spring" procedure to me.
Next projects planned:
hot side intercooler boots
exhaust manitold gaskets
coolant flush & coolant filter install
Old Apr 3, 2011 | 11:20 PM
High Binder's Avatar
High Binder
It's super easy. I did mine while the housing was out of the truck but it would be just as easy to do it while it's in. It's simply a matter of pulling the little cover and replacing the spring and all of the little parts that come with the kit. Should take you about 10 mins. I think the kit was ~$50 on ebay. I don't know what my pressures were before (no gauges) but I installed gauges at the same time and now read around 65-68 all the time. I think the biggest problem you might run into is catching the leaking fuel, again I did mine while the whole assy was out of the truck so I have no idea how much fuel might leak but no matter what it won't be more than is in the bowl.
ballbandit
Oct 7, 2014 11:23 PM
DownTown25
Sep 18, 2013 02:13 PM
Money-Pit
Jan 6, 2013 11:51 AM
weldworks54
Sep 3, 2011 11:37 PM
belandd
Oct 12, 2007 04:04 PM
